Cab center brace?
Old May 13, 2013 | 03:38 PM
rottenstock's Avatar
rottenstock
Cab center brace?
Is this suppose to be attached to the roof or have a gap?
If it's not suppose to have a gap, what's the best way to re-secure it to the roof?
What's this actually called? Does it only go in one way? I think it's been removed before and re attached. Not sure though
Old May 13, 2013 | 04:13 PM
sloopy76's Avatar
sloopy76
Yes mine has that too. Mine is covered by a headliner though. I'm not sure if there's supposed to be a gap or what is normal for a gap.
Old May 13, 2013 | 04:16 PM
rottenstock
I don't have a headliner (obviously) :P
I plan on getting one though. Just trying to figure out the roof support beam thing.
Old May 13, 2013 | 04:22 PM
HIO Silver's Avatar
HIO Silver
It's supposed to follow the curve with a lil bit o' padding but some fat azz has usually sat on the roof and inadvertently bent it down. It's tack welded front and rear.
Drill it out, re-curve it, and reinstall. Alternatively, replace it with framework for a ceiling mounted console with map lights, toggle switches, and maybe a CB.
Old May 13, 2013 | 04:32 PM
rottenstock
Is it just a matter of pulling it off and re-bending it by eye?
It looks like the roof had some welding done to it, like they had some antennas up there or something.
Old May 13, 2013 | 05:35 PM
jim collins's Avatar
jim collins
You can redo it but i would put some kind of pad above it if not it might rattle a little from rubbing the sheet metal. Yeah, looks like somebody got on top of the roof and bent it down.
Old May 13, 2013 | 05:38 PM
rottenstock
Old May 13, 2013 | 06:50 PM
HIO Silver's Avatar
HIO Silver
Which other way would there be to install it??
Old May 13, 2013 | 06:53 PM
rottenstock
Backwards?
Old May 13, 2013 | 08:05 PM
lafermedavid's Avatar
lafermedavid
roof brace
I ground the welds ,removed mine to be able to sand roof down,prime the roof and the brace,and re tack weld,insulate the ceiling,before adding panel By removing mine ,I was able to pull down the rear metal some and sand ,and spray with rust inhibitor and prime,which I would not been able to do with brace intack
Old May 13, 2013 | 08:07 PM
rottenstock
I guess what i meant was: is there a front and a back or does it not matter?
Old May 13, 2013 | 09:13 PM
460 FORD MAN's Avatar
460 FORD MAN
I would just mark the front and rear of it, so when you take it out you can re-install the same way it came out.
Old May 13, 2013 | 09:25 PM
rottenstock
That's would I would think as well, but it looks like it may have been out once before....
Old May 13, 2013 | 09:28 PM
HIO Silver's Avatar
HIO Silver
It doesn't matter...
the only time it would matter is lining up the one screw hole right smack in the middle of headliner with the brace. However, you don't have that problem.
Old May 13, 2013 | 10:48 PM
KawKaw's Avatar
KawKaw
Cab center brace?
Greetings, Rottenstock
I just checked out my two un-molested examples in the basement. The notch and hole go towards the windshield. Yours is in right. Both of my headliner braces run approximately 1/2" below the roof sheet metal. I pulled the headliner on my running truck the other day and found that at some time mice had set up camp in the insulation. I pulled the seat, dash panel and radio, then hosed down the entire interior. Sure smells better now, along with duesching out 37 years of accumulated dust. Much better to work on the wiring, before this I would feel grungy just getting in and out of the truck.
sodapop curtis
Aug 30, 2017 12:18 PM
austinlibke
Sep 5, 2012 12:39 AM
jgavac
37
Aug 30, 2011 09:12 PM
hotrodtodd
Dec 12, 2009 04:31 PM
Monsta
Mar 29, 2008 12:31 AM
