Thanks for the tip... Its going to the machine shop. I don't have the tools to measure those tolerances and I don't feel like removing the cam to try the trial and error alternative approach.
Because it's doubtful that you can precisely drill the hole in the new gear exactly thru the old hole. If you're off even a little bit, it throws the gear off the needed dimension. Seems like it would weaken the shaft, but it was never a problem with either of the ones I did. And one had a HV oilpump.
