horsepower
Old Jun 10, 2003 | 09:04 PM
mwittman's Avatar
mwittman
horsepower
Not sure if you have an auto or not but this kit is awesome if you do. This may not "add" HP to the motor, but is sure does help get it to the wheels. I bought mine from www.txchange.com. It was something like $30 to my door. Takes about 2-4 hours to install yourself, or take it to a pro and pay $100-200. This kit absolutely brought my tranny to life. No more sluggish shifts. No more occasional gear hunting. And it's not too harsh either. I'm tellin' ya man, if you've got the power in your motor, then you need to add one of these! You WILL accelerate faster with this kit.
Matt
Old Jun 12, 2003 | 03:15 PM
2000ranger's Avatar
2000ranger
horsepower
know I have no idea what a valve body shift kit is but i have a manual trans. wouldn't have it any other way. does this kit work for manual?
Old Jun 12, 2003 | 04:23 PM
mrwizard's Avatar
mrwizard
horsepower
No. Just autos.
Old Jun 12, 2003 | 09:14 PM
phatpharm85's Avatar
phatpharm85
horsepower
if i were you i would dump the flows and go with a good dynomax catback, they flow much better and cost less.
Old Jun 12, 2003 | 11:01 PM
trojanman25's Avatar
trojanman25
horsepower
what exactly is the point of changing the MAF? if its a beneficial gain, how much does it run?
2000ranger, where did you order yours from?
im seriously thinking about that shift kit from transgo
Old Jun 13, 2003 | 12:10 AM
baddad457's Avatar
baddad457
horsepower
To get any benefit out of an exhaust system, you have to first have a motor that needs the extra flow , like a V-8 . Nothing beats more cubic inches. Go for a V-8 if you really are serious about more power , or go the supercharging route.
Old Jun 13, 2003 | 02:30 PM
98blownranger's Avatar
98blownranger
horsepower
the stock exhaust is very restictive if you chace only the exhast(cat back) you will see and feel nice gains
curt
Old Jun 13, 2003 | 06:27 PM
baddad457's Avatar
baddad457
horsepower
Yea, my 89 gained so much power after I cleaned out the guts in the cats with the 2.9 that I couldn't tell the difference. Now when I stuck the 302 in there ------- I said : WOW I could have had a V-8!!!!
Old Jun 13, 2003 | 10:57 PM
98blownranger
horsepower
gutting your cats is a bad idea, for many reason and you willnot gain anything for power I know a few guys that made back to back dyno runs with gutted cats and with a stock cat (supercharged 4.0's)
curt
Old Jun 13, 2003 | 11:13 PM
baddad457's Avatar
baddad457
horsepower
You may not gain anything , but you sure won't lose anything either. If the backpressure created by the cats is so beneficial, why then would you want to get rid of any other backpressure creating restrictions down stream from the cats? As in 2.5 inch+ single and dual exhaust systems with low restriction mufflers and "mandrel bent" pipe on a motor that can't even use half the extra space in the system. Think about it. Most of what anybody gains from high dollar exhaust systems doesn't even register on the seat of the pants scale and the perceived benefit is mostly created in one's own mind. I'm running a 2 inch muffler shop exhaust with 30 inch glasspacks behind a 325 HP 302 in my Ranger and it runs just fine. And I ain't about to go out and spend 400+dollars for a system like that.
Old Jun 13, 2003 | 11:41 PM
98blownranger
horsepower
well you will lose a good flow due to the exhaust expandind in the oping and then having to compress again to get out, you are beter off replacing it with a pipe, I take you you have 2 2.00 pipe not one? if you hve one you must have a ton of backpressure! I have taked to a few exhaust companys and they all say the the 300 hp mark is the limits for 2.5 inch single pipe. not saying you can't have more hp than that but you will not get what you should. I have 2.5 inch mandrel.... on mine and but over 200 to the ground so I am in the balpark you are claiming and I know I am using all the size I have due to the high level of back pressure. I am at the limit and will go to a single 3.000 inch pipe when my heads and new cam are done.
curt
Old Jun 14, 2003 | 12:09 AM
baddad457's Avatar
baddad457
horsepower
200 hp on the ground? with a V-6? What are you smokin? Yes I have 2 inch duals. You've also got to remember that the exhaust companies are in the business of SELLING YOU AN EXHAUST SYSTEM. You really think they're about to tell you that your V-6 doesn't need that extra wasted space in your pipes? When you do get your heads and cam done, run it as is, then spend more on the exhaust if you feel it's holding you back. If you think that exhaust having to contract after expanding in an empty chamber ( gutted cats) is a bad thing , then why do the dirt bikers get off on expansion chambers in their exhaust's?
Old Jun 14, 2003 | 10:36 AM
  #28
98blownranger
horsepower
a dirt bike motor is way diferent that a truck motor, and yes right now I have 200+ to the ground and do a few others with a simalier setup. I have everybolt one and am running 9psi with the option of a 12psi when I want to play. and yes I will out run most mustangs in my town. I have been in may of these discustions before and many people tend to think the way you do, so you aree not alone.
as for your piping you would be best off with a manderal bend dual 2.25 with a X or H pipe.
curt
Old Jun 14, 2003 | 08:54 PM
  #29
baddad457's Avatar
baddad457
horsepower
I'm about to swap on a set of Canfield aluminum heads and an Edelbrock Vic Jr. next month. When I do , I'm going to replace the 2 in and glasspacks with a set of Shelby style Tri-Y headers and a 2.25 in muffler shop special ( no mandrels here, don't need them) and either a set of turbos or maybe some quiet factory style mufflers ( I like sleepers )How much did all those bolt on mods run you? Might have been better off swapping a V-8 in.
Old Jun 15, 2003 | 01:08 AM
  #30
mrwizard's Avatar
mrwizard
horsepower
Many places that have emissions inspections won't allow that kind of swap. Where I'm at, you are limited to what kinds of engines were available that year in that model. So, getting a V8 Ranger to pass emissions would be a really cool magic trick.
