towing in over drive
Old May 11, 2013 | 02:19 PM
rockcrawler_101's Avatar
rockcrawler_101
I have a 02 with the v10 and 430 gears, should I tow in over drive. I have always done it in the past but just want to make sure its ok to do so with my excursion. I had a manual in my super duty so it wasn't an issue. I tow at max 7500 pounds with my jeep and trailer.
Old May 11, 2013 | 02:25 PM
ScaldedDog's Avatar
ScaldedDog
Do it, unless the tranny is hunting between gears.
Mark
Old May 11, 2013 | 05:38 PM
greenwoodford's Avatar
greenwoodford
I just moved from Washington state to Texas and towed a 7k+ trailer with my 2001 V10 with 4.30 gears. I left it in overdrive except through some hill country and mountains where it wanted to drop out frequently.
Old May 11, 2013 | 05:50 PM
Tom's Avatar
Tom
I agree with the above, I've towed 16,000 lbs in overdrive in the past with no issues. Unless you're hunting between gears leave it on regardless of what you're pulling.
Old May 12, 2013 | 09:44 AM
Wilmax's Avatar
Wilmax
I also tow my 7000 lb trailer in OD. When I have it in cruise control it will downshift on the least hill but I find if I control it with my foot out of cruise it doesn't shift down as much and is a much nicer tow. BTW mine is a V10 4X4 with 3.73 gears.
Old May 12, 2013 | 08:22 PM
rowekmr's Avatar
rowekmr
When I had mines with 4.30 gears I left it in OD while towing my 9K travel trailer. It seems with those gears I would be in the torque band at 65-68mph so it didn't have to downshift much unless on steeper hills. What I would do to minimize multiple downshifts would speed up slightly before a hill and allow the truck to slow down some. If left on cruise it would downshift 2 gears then upshift one so I avoided some shifts that way.
wickdgt
Modular V10 (6.8l)
29
May 3, 2015 07:01 AM
wickdgt
Mar 7, 2015 08:46 AM
nvreloader
Aug 24, 2006 10:28 AM
paradiddle
Modular V10 (6.8l)
Dec 1, 2003 07:17 PM
WKMOTZU
Mar 21, 2003 10:12 PM
