Intake Manifold
Old May 11, 2013 | 01:52 PM
FP's Avatar
FP
Intake Manifold
Are the manifolds for the Flathead interchangeable with the Y block V8? I'm having my carb rebuilt, and the the guy rebuilding it believes it's from a flathead. Does that make sense?
Old May 11, 2013 | 01:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The manifolds are completely different, but both use 3-bolt carbs with the same bolt pattern. Flatheads used the Holley 94, Y-blocks used the Holley model 2110, which is an evolution of the 94. Why does he think it's off a flathead?
Old May 11, 2013 | 02:41 PM
FP's Avatar
FP
Just because of the base pattern, but thanks for the model number information.
Old May 12, 2013 | 08:41 AM
Dale Fairfax's Avatar
Dale Fairfax
He's only seeing the carburetor-which is very similar to those used on Flatheads. In fact, over the years someone may have replaced the one on the Y-Block with one from a Flathead. Everything from 1949 thru 1955 was practically the same.
Obviously. there is NO similarity, other than the carb mounting flange, between the two engines.
Old May 12, 2013 | 01:36 PM
FP's Avatar
FP
Thanks guys. This is helpful.
Scout Pilot
Apr 2, 2012 09:09 PM
Brian's 48
21
Feb 1, 2011 08:38 PM
mason55
Dec 19, 2005 07:46 AM
youdog99
13
Sep 24, 2002 08:58 PM
