Intake Manifold Question
Old Apr 1, 2012 | 09:15 PM
Scout Pilot's Avatar
Scout Pilot
I found this on eBay. Are these all interchangable? I have a 292 in my F-100. Do I have to do some number crunching for compatability?
1956 Ford T-Bird 292/312 Intake Manifold ECZ-9425-A Thunderbird Y-Block | eBay
Old Apr 1, 2012 | 10:42 PM
tinman52's Avatar
tinman52
Welder User
They all interchange......that manifold uses the old square pattern carb. Is that the type of carb you plan to use? Modern 4 barrels will not bolt up without an adapter....
I have one of those manifolds you can have for half that amount...
Old Apr 2, 2012 | 05:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DO NOT BUY IT, it's a 1956 manifold. It will fit all 272/292/312 Y blocks, but 1956's (and 55's) used the 'teapot' Holley carbs that have a specific carb bolt mounting pattern that was not used after 1956.
The 4V manifold you want was used on 1957 292/312 Ford/Merc/Thunderbirds. Very popular, very desirable, hard to find because the teapot carbs used on 1955/56's were crap.
Owners of 1955/56 T-Birds, Fords and Mercs have bought up and installed many of these 1957 manifolds for this very reason.
btw: The 1955 Y block manifolds are different from 1956, as the auto choke assy mounts on the manifold itself, not on the carb.
Old Apr 2, 2012 | 10:43 AM
arctic y block's Avatar
arctic y block
I had a tea-pot on my 55 Town Sedan. It's also called a flame thrower and for good reason.
Old Apr 2, 2012 | 07:07 PM
Scout Pilot
thanks numberdummy
Old Apr 2, 2012 | 07:11 PM
Scout Pilot
tinman....is it the same manifold or a different one
Old Apr 2, 2012 | 08:56 PM
Scout Pilot
I would like a 4 bbl manifold but my budget is minimal.
Old Apr 2, 2012 | 09:09 PM
arctic y block
Aluminum aftermarket aint to hard on the wallet. Other than that a cast iron factory on from a junk yard. Heck check e-bay, craig list
hellbilly1932
Mar 4, 2007 11:01 PM
bob s jr
Nov 20, 2006 08:03 PM
gota292
13
Sep 13, 2006 04:50 PM
mason55
Dec 19, 2005 07:46 AM
doublej80304
Oct 17, 2004 06:10 AM
