Frame width
Old May 10, 2013 | 07:45 PM
talisker's Avatar
talisker
Frame width
Does anybody know why Ford made the frames narrower on the 1973-78 Crew Cabs and High Boys? I just bought a hitch for my 1973 F250 High Boy and it was too wide. I called Curt Manufacturing and they said that I needed the narrow model. Amazon admitted that the Crew Cab needed a different hitch but said nothing about the High Boy. It seems that it would be to the manufacturers advantage to stay with one width.
Old May 10, 2013 | 09:04 PM
meborder's Avatar
meborder
cant help you with the "why's"
but for the record the trucks with the 140" wheel base have the same narrow frame width. (34-1/4"?)
i got burned too, as none of the manufacturers list the 4x2 f350's as being different than any others.
Old May 10, 2013 | 11:02 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by talisker
Does anybody know why Ford made the frames narrower on the Crew Cabs and High Boys?
The real question should be why did Ford widen the frames after the highboy era...
From '61 to '77 highboys (and crewcabs) both shared the straight, ladder style 34" frame.
In '77 Ford widened the frame to 38" (from the cab rearward) making for a weaker frame, they also married the T-case, lowered the suspension, and imo made it less of a "truck".
Old May 11, 2013 | 05:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
33 1/2" width between the inner frame rails behind the cab: 1961/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79 F350 Cab & Chassis / 1973/79 F350's on the 140" wheelbase.
All other 1973/79 F100/350's have 37 1/2" width inner frame rails behind the cab.
Old May 11, 2013 | 09:04 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
ND all the crew longbeds also had the narrow frame regaurdless of year. not sure if they would classify those as c&c. i wouldnt think so as they came with a factory pickup bed.
privateer, eh
25
Jul 30, 2013 03:52 PM
Chucky Babe
Jan 13, 2010 04:07 PM
truckman15
Sep 4, 2007 11:30 PM
backwoodspuller
Offroad & 4x4
Oct 13, 2006 09:43 PM
BULGOD
Nov 20, 2002 12:19 AM
