Stalled F 150
Old Jul 24, 2002 | 09:41 AM
osolamio's Avatar
osolamio
Stalled F 150
Hello,
I have a 1988 F150 1/2 ton etc....
I have tried everything from replacing the external pressure pump, to a new computer to get it running. This is a fuel injected truck as you may have guessed. I tried to bleed the air out of the line, but still no start.
Any suggestions?
Ken
Old Jul 24, 2002 | 06:57 PM
Redneckerson's Avatar
Redneckerson
Stalled F 150
What happaned to the truck? Did you just buy it? Anyway don't overlook the simple stuff such as secondary ingition components Wires, cap, rotor Initial timing. Does it turn over but not start? Let us know and it really shouldn't be to hard to get it running.
RSH
Old Jul 25, 2002 | 01:14 AM
soso's Avatar
soso
Stalled F 150
I had that problen once turns out the little groung wire on the negetive side of the battery was not pluged in(fuel pump ground)
another time it was the relay under the master cylinder
hope that helps
Old Jul 25, 2002 | 08:21 AM
michaelskerrett's Avatar
michaelskerrett
Post Stalled F 150
Old Jul 25, 2002 | 02:50 PM
osolamio's Avatar
osolamio
Stalled F 150
[updated:LAST EDITED ON 25-Jul-02 AT 03:52 PM (EST)]Thanks for the help!!
I was driving down the road and it sputtered and died. Then it would run a few minutes and die again. The last time it started was the time I got it home. Both tanks read full, I am just out of ideas. I am going to try to bypass the switches and run one tank straight. If you all have any other ideas, please help. I am really desperate.
Ken
I have a full tank in the back and the front has about 10 gallons
86moneypit
1997 - 2003 F150
May 14, 2013 10:46 PM
Ken A.
Mar 18, 2009 10:06 PM
ken's 80
Oct 30, 2008 09:17 AM
TJPF150
Computer Chips & Tuners
Mar 10, 2004 09:38 PM
AZ4x4f150
Mar 26, 2002 11:52 PM
