Engine Failure at 44,600 Miles
Old May 9, 2013 | 10:00 PM
vince474's Avatar
vince474
Early this morning I fueled my truck near my house where I always do. I started up a slight hill and all the sudden the truck lost power, the message display read "reduced engine power" and it quit running. I pulled over and tried to restart it and it just made 1 click.
No fluids under the truck, the serpentine belt was ok, both batteries were showing green. I thought maybe the timing chain broke at first.
I called Ford Roadside service and had it towed into the Ford Dealer. At about noon I get a call from them telling me the #4 tip of the glow plug broke off inside of the engine and caused extensive damage inside the motor. They are tearing it down and getting a brand new long block for it from Ford. The dealer says 7 to 10 days.
Luckily I have a 99 Ford E350 boxvan I use as a backup unit for work. Anyone ever hear of this happening? It just had a brand new water pump and radiator replaced about 2 months ago under warranty as well.
Vince Wood
Chino Hills, CA
2011 Ford F-450 12' Flatbed 6.7L Diesel
Old May 9, 2013 | 10:15 PM
powerstroke451's Avatar
powerstroke451
Heard of a few engine failures but none from that cause. Sorry to hear about your truck but at least it was warrantied. Keep us posted on progress
Old May 9, 2013 | 11:00 PM
King_Kong_01's Avatar
King_Kong_01
Vince Wood
Chino Hills, CA
Los Angeles Power Washing - Alert Power Washing
That's not good.
I never thought it was possible with a glow plug these days, but as you can see...
BJ
Old May 9, 2013 | 11:48 PM
gopedoligist's Avatar
gopedoligist
just one more thing for me to think about as i inch closer to being out of warranty.... oh goodie LOL
Old May 10, 2013 | 06:02 AM
rcjohn44's Avatar
rcjohn44
A friend with a 2011 that transports RV's out of Elkhart, IN, had about 250,000 miles, picked up load of fuel that had a lot of water in it. Enough water that it went past the separator and caused an injector to break causing the same type of damage Vince474 is describing. Replaced the entire engine.
Old May 10, 2013 | 09:02 AM
vince474's Avatar
vince474
The funny thing is that I know the guy that used the exact same pump right after me when I fueled. He is a plumber that has a E350 with a 6.0L in it. He went right by me when I was broke down. I'll talk to him and see if he had any problems the next time I see him.
Old May 10, 2013 | 10:29 AM
SavageNFS's Avatar
SavageNFS
I hope they get you fixed up soon and it's done right. Sorry this happened to you...
Old May 10, 2013 | 11:22 AM
tolliewolly's Avatar
tolliewolly
Dang I hate to hear that. I am sure Ford will take care of you. They are pretty serious about this truck.
Old May 10, 2013 | 11:33 AM
vince474's Avatar
vince474
The funny thing is that the backup unit was actually up for sale due to my wife telling me that I never use it and it just sits in the driveway.
I told her the truck will be out approximately 7 to 10 days. 10 days at $60 a day for a rental pick up. $150 a day at 10 days for a rental pressure washing trailer. That's $2100 in rental equipment I just saved us.
She said I can keep the backup unit now and also said "as soon as that truck hits 100,000 miles and it's out of warranty then it's getting traded for a new truck"
Vince Wood
Chino Hills, CA
Old May 10, 2013 | 11:36 AM
SavageNFS's Avatar
SavageNFS
Does the backup have the pressure washer mounted on the truck?
Old May 10, 2013 | 11:49 AM
vince474's Avatar
vince474
Yes, it's actually in a 14' Box Van. It's a Landa 7.6 GPM 3600 PSI hot water unit. You can PM me if you would like to know more information about it.
Vince Wood
Chino Hills, CA
2011 Ford F-450 6.7L Diesel 12' Flatbed.
Old May 10, 2013 | 12:00 PM
SavageNFS's Avatar
SavageNFS
No I was just curious as to why a truck would save a rental mobile power washer, but I do understand if it has a unit on it. Thanks and good luck.
Old May 10, 2013 | 10:07 PM
Chad149's Avatar
Chad149
The couple engine failures that I recall were for an exhaust valve cracking issue on 2010 production trucks and some of those started as a broken glow plug diagnosis. When was your truck made?
Old May 10, 2013 | 10:39 PM
vince474's Avatar
vince474
I believe the build date was 7/2010. I know it was a Job 1 truck. I think it's a little late but the next truck I get I'll get the 200,000 mile extended warranty when I buy it, if Ford offers one.
Vince Wood
Chino Hills, CA
Old May 11, 2013 | 07:31 PM
Maxium4x4's Avatar
Maxium4x4
I suppose since you are a business, the extended Warranty would not be offered, curious though if they do differentiate a Business from Personal.
