couple questions while engine is out
Old May 9, 2013 | 08:19 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Anything special I should do while the engine is out of the truck?
6.0 intercooler an upgrade?
Banjos?
Oil cooler rebuild?
What ya guys suggest.
Old May 9, 2013 | 08:23 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
All o-rings on top of engine. Get em done while you can access backs of heads, etc.
Old May 9, 2013 | 08:37 PM
Mowing Man's Avatar
Mowing Man
Oil pan if original is metal. Also, check the metal fuel lines near the front axle to see if they're rusted out. Much easier to do in an empty engine compartment. If mine was ever out again, I'd probably see how much new up pipes cost too.
Old May 9, 2013 | 08:46 PM
diesel-fitter-bum01
I believe most all orings have been replaced in the last two years.
Going to a new oil pan,will check the fuel lines. Already have bellowed uppipes. Depending on how long its down,I might just put the T4 pipes in and go from there.
Old May 9, 2013 | 10:04 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'd love a t4 setup and wide open turbo options...
Old May 9, 2013 | 10:07 PM
diesel-fitter-bum01
Yeah,got the pipes. Just need to decide on the turbo. Build the oil lines and cooler tubes.
Mowing Man
17
Feb 10, 2014 12:35 PM
Dholtham
Jan 31, 2013 09:42 PM
Kwikkordead
62
Jan 2, 2010 11:36 AM
papagiddyup
Jul 9, 2006 11:30 AM
pdvan
Feb 26, 2004 08:59 PM
