HELP !
Old May 9, 2013 | 05:03 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question HELP !
Im in the middle of the installation of the coolant filter and Im having trouble to unbolt the plug of the water pump in the left side below of the thermostat, it is frozen (I hope I explain myself), what to do?
Thanks in advance
Old May 9, 2013 | 05:11 PM
ReBilld's Avatar
ReBilld
Have you sprayed it with any kind of penetrate? Try tapping on the end of the plug with a small hammer.
Old May 9, 2013 | 05:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
No I havent use any, Im going to tapping it, and spry some penetrate, I only have WD40
Old May 9, 2013 | 05:21 PM
ReBilld's Avatar
ReBilld
Good luck with it buddy
Old May 9, 2013 | 05:23 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
The space is very tight there. Im also going to reseal the thermostat because is leaking. I have de 203*, can I reuse the stock one? I think it is in good conditions
Old May 9, 2013 | 05:44 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I spryed with some penetrate and tapped with a little hammer, and no dice, Im going to wait some more time. With a pic, I cleaned the perifery (spl?) of the plug and it looks like a red stuff there, IDK.
Edit: Im opening my first beer.
Old May 9, 2013 | 06:21 PM
ReBilld's Avatar
ReBilld
If your t-stat is in good shape and working properly, I don't see why you couldn't reuse it, but if I was in there anyway, I'd replace it, but that's just me.
Is the end of the plug square Jose? There are sockets that fit the square studs. If you could get one, maybe with an extension and swivel, you could give it a couple bumps with an impact.
Old May 9, 2013 | 06:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
No the square plug NO dice, I put more penetrant and Im waiting. Yes I found a socket that fit, Im going to figure out IF I can get the combo to get there with an impact.
The thermostat was working fine, just I saw the ad of diesel site and the comments here in FTE and convinced mi to change for the 203*, but now its leaking, maybe I just put sealant and reuse the actual 203*. More, I cant find the OEM rigth now, I dont know where I stored
Thanks for your help
Old May 9, 2013 | 08:16 PM
fordpride's Avatar
fordpride
50/50 mix of ATF and acetone works great
Penetrating Lube Test: Grassroots Motorsports forum: Grassroots Motorsports Magazine
Old May 9, 2013 | 08:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Unhappy
Well after several hours trying to unbolt the plug, I gave up, maybe next saturday I will continue, and if I cant, Im going to use the heather hoses to install the bypass and also I hope I can do the AC mod and the t/stat
Old May 9, 2013 | 08:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
Originally Posted by fordpride
Yeap, I forgot that, Im going to try that, thanks Mike.
Old May 9, 2013 | 09:46 PM
oldbird1965's Avatar
oldbird1965
Jose, if your going to wait until next weekend then soak it every day and like Bill said, tap it with a small hammer each time. Good luck.
Old May 9, 2013 | 10:18 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
thanks Glenn, Ill do that and with the Mike's formula
Old May 9, 2013 | 11:24 PM
richdawg's Avatar
richdawg
Sorry to hear you are having so much trouble getting that plug out, my biggest problem was finding something that would fit the square hole. Mine came right out almost like it was already loose. I think you are on the right track with the advise your getting here good luck
Old May 10, 2013 | 06:08 AM
fordpride's Avatar
fordpride
Just make sure you don't get the ATF and acetone on your belt or hoses
