351 HO cam
Old Jun 7, 2003 | 07:07 AM
damtyred's Avatar
damtyred
351 HO cam
Can anyone give me specs on 86 351 HO flat tappet cam? Specs, casting #, etc.
Old Jun 7, 2003 | 07:57 PM
Rodbuckler's Avatar
Rodbuckler
351 HO cam
I measured the HO cam specs when I pulled the engine at 200K. The lifters had a fairly broad wear pattern, but the cam was still in good shape.
The intake lobe measured:
284deg duration at 0.004" tappet lift
206deg duration at 0.050" tappet lift
112deg duration at 0.200" tappet lift
0.283" max tappet lift
112deg ILCA defined at 0.050" tappet lift
The exhaust lobe measured:
290deg duration at 0.004" tappet lift
218deg duration at 0.050" tappet lift
110deg duration at 0.200" tappet lift
0.272" max tappet lift
120deg ELCA defined at 0.050" tappet lift
Old Jun 7, 2003 | 08:09 PM
damtyred's Avatar
damtyred
351 HO cam
Thank you very, very much. I have the engine that came out of my trk. which is supposed to be a 351 HO. Do you happen to know what identifying marks are on this cam? I'd like to be sure its an HO part. Again thanks,Bill.
Old Jun 7, 2003 | 08:20 PM
Rodbuckler's Avatar
Rodbuckler
351 HO cam
I found the cam in the shop. I think it has these marks, although some were illegible:
6 G
E1
0 3P
15 15
Old Jun 7, 2003 | 08:43 PM
damtyred's Avatar
damtyred
351 HO cam
Thanks again. I'll check mine later &see if it has these markings.
pintoches
May 17, 2011 08:15 AM
Nightrain
Aug 19, 2007 11:37 AM
Jrock909
Mar 18, 2007 07:19 AM
Desertwolf
Mar 6, 2007 08:50 PM
Quantrex
Sep 1, 2002 09:03 PM
