Need Help Diagnosing problem ASAP plz
Old May 9, 2013 | 09:40 PM
BLADE35's Avatar
BLADE35
Everything the Guys are saying here with Low Fuel Pressure
Low Fuelpress will Scar Injectors Plunger then it can start Hanging up at this point fuel free flows in cylinder
Fuel press basicaly Lubes the injectors
The Pressure isnt that high Normaly Just if there is Raw Diesel fuel in the cylinders and the Glow Plug is Out when the engine is cranked all the Fuel comes out the Glow Plug Hole
The engine is an Interferance engine meaning the piston Just about Kisses the Head at TDC (Top Dead Center) the interferance comes when the Valve timing gets Off for whatever reason and Piston Hits the Valve
But since the engine is interferance any liqued Fuel will come out that Glow Plug Hole with GREAT FORCE
You just dont want to be looking in there when engine is cranked that first couple revolutions Let it Vent the diesel fuel First then you can check it out
Any injector that has a Problem will have Heavy Mist coming out the GP Hole
Old May 9, 2013 | 10:01 PM
Raptor13's Avatar
Raptor13
Benny, Thank you sir for all this information. Looks like me and the yellow jacket will be taking the black widow for surgery tomorrow.
lwarrior1016
Nov 24, 2023 06:43 AM
ExPACamper
49
Mar 31, 2015 03:52 PM
64F260
Apr 30, 2010 05:23 PM
BmanRRT
Jun 21, 2007 08:56 PM
dew487
Feb 22, 2006 06:17 AM
