Sponsored by: Auxito
Odometer reading
Old May 8, 2013 | 08:57 AM
chaser1602's Avatar
chaser1602
Odometer reading
@000 f150 lariat. Isnt the odometer display controlled by the computer? If I buy another cluster wont my mileage be the same reading as my truck, not the donor?
Old May 9, 2013 | 09:21 PM
Bluegrass 7's Avatar
Bluegrass 7
No, the dash has it's own micro processor and data storage.
The PCM only supplies real time update to it from vehichle speed sensing.
The update is not the mileage but signals to drive the dash counters (ring counters), they in turn drive the matrix display you see as mileage..
Almost everything is digital now.
As well, you need dealer service if PATS is involved or your keys will not start the motor because the dash, pats and the PCM become 'married' by code.
This is the THEFT system at it's finest.
Good luck.
Old May 10, 2013 | 07:04 AM
chaser1602's Avatar
chaser1602
Thanks for the answer
Old May 12, 2013 | 07:47 PM
Fox Fader's Avatar
Fox Fader
2 add, you can swap the processors if you want to swap clusters, but keep your current mileage count.
Old May 13, 2013 | 04:42 PM
chaser1602's Avatar
chaser1602
The processors must be in the cluster somewere. And they look like what???
Old May 13, 2013 | 08:37 PM
Fox Fader's Avatar
Fox Fader
I'm not sure on this cluster, but just follow the ribbon cable from the readout display.
GuitarJesus
18
Sep 4, 2018 12:29 AM
coreylasalle
Apr 2, 2014 08:34 PM
Club Wagon
Mar 14, 2010 03:36 AM
NitrousNolan
Mar 20, 2009 03:39 AM
misti430
Apr 16, 2002 08:27 AM
