engine swap
Old May 8, 2013 | 02:30 AM
frank_kay1's Avatar
frank_kay1
engine swap
I have a 93 ford f150 with an inline 6. Motors toast but have a 96 f250 with a 5.8l 351 w. That engines good. Gonna swap out motors to 150. Guess my question is will the motor mounts need to be swapped out? What else would i need to swap out too? If anybody could help id really appreciate it
Old May 8, 2013 | 08:07 AM
blue924.9's Avatar
blue924.9
if i may ask how did you kill the inline?
Old May 8, 2013 | 09:04 AM
garrett_8's Avatar
garrett_8
drained the oil filled with water drove for 300,000 miles turning max rpms
when that didnt work drained the oil filled with gas still didnt work
ran it dry kept running
finally loaded it up with c4 and the belt fell off so he wont fix it
Old May 8, 2013 | 01:01 PM
UNTAMND's Avatar
UNTAMND
You can use frame mounts and hardware from the 96.
Best and easiest way to wire it up will be to grab an engine wire harness from a 93 truck and it will all plug right in and run.
Old May 8, 2013 | 01:37 PM
garrett_8's Avatar
garrett_8
whats wrong with the new F250 to swap the motor out of it?
Old May 8, 2013 | 03:24 PM
frank_kay1's Avatar
frank_kay1
96 front end is screwed. Not to much i can do with it. 93 has a good body, frame, and everthing seems to be in tip top cept motor. Thanks for the info untamnd
Old May 8, 2013 | 03:29 PM
frank_kay1's Avatar
frank_kay1
With me swappin both motor and tranny would i need to switch drive lines too or would the 150 drive line work
Old May 8, 2013 | 03:33 PM
frank_kay1's Avatar
frank_kay1
Garret 8, the inline was blown before i came across it. Was a company truck and nobody seemed to do the daily or weekly matinence on it. Blown head gaskets are the rumor. Need to check it out myself
Old May 8, 2013 | 03:50 PM
UNTAMND's Avatar
UNTAMND
What trans in each truck.
Sometimes trans is in exact same location and your driveshafts will be fine in the 150. The 250 has different lengths because the diffs are bigger.
Someone else will need to fill you in on potential trans wiring differences (if both are e4od trans) Technically the 351 will bolt to the 300-6 trans. So if the 96 ecu is speed density then no extra wiring for trans is needed I don't think.
Old May 8, 2013 | 04:06 PM
frank_kay1's Avatar
frank_kay1
I dont have the 150 on hand right now so dont know the trans yet. So guessin best thing is to get it here and go from there. Thanks again for info untamnd
Kevin Frens
Apr 22, 2014 07:44 PM
cherrybomb37
Mar 24, 2014 09:21 AM
Rissa' Bert
Apr 12, 2008 05:01 PM
mike manglos
Nov 22, 2006 02:28 PM
bowlerman
Feb 27, 2006 04:12 PM
