Help...Valve Train Noise 390 FE
I have a 390 FE in my 76 Highboy. It has a performance CAM. Not sure the brand or specs. The engine has a valve train tap/knock. It seems to fade when I rev it or shift to a higher gear with medium load. I tested the compression, all are within 95 to 120 lbs. Oil pressure is decent. Seems to drop as engine warms. Spent the last 2 Saturday's replacing all the lifters thinking it was definitely a lifter problem. But, its still making noise. Not sure where to go from here. Only thing I noticed is when I remove the #4 spark plug wire. The sound doubles. Not louder, just sounds like two clicks instead of just one. Any comments or help would be greatly appreciated.
Here's a link to a video:
https://www.facebook.com/photo.php?v...66305494036531
If you think you know what cylinder is causing it, i would pull the sparkplug and both the intake and exhaust pushrods for that cylinder and let the valve cover off. That will let you know if its a drivetrain noise, or somthing worse. That sounds like a loud noise to be a lifter.
are your valvesprings ok? The lobes on the cam look ok?
sorry for the confusion. I was meaning this.
If you pull the pushrods both the intake and exhaust pushrods and the spark plug from the cylinder you think it is (since you think you know what cylinder is causing the noise) and start it you should be able to tell if its a valve train noise if it doesnt make the noise with the engine running since there would be no load on the lifters, valves, or cam lobes for that cylinder
The reason for pulling the plug is to relieve the pressure from that cylinder to make it turn over easier since both valves will be closed. And with both pushrods out of that cylinder there will be no load on those 2 lobes, and lifters. So that will let you know that somthing under load is making noise in that section of the valve train. Now, I'm assuming that if somthing is going on with the cylinder itself that it would still make that noise even without that cylinder firing. So theres a chance if it still does the noise and you have tried all the cylinders that you think are causing the problem that it could be rotating assembly related.
Now on another note. I'm wondering if you remove all of the plugs (to make it spin faster) and turn it over starter speed if the rotation of the starter would be fast enough to cause the noise you are hearing? If so you could just do that and narrow it down without having to fire the engine while its partially torn apart.
These are just brainstorms and i'm not a engine pro like some guys in here, but i have found with most things the best way to find a problem is by removing parts of the equation a piece at a time if there is a realistic way of doing so.
EDIT
I forgot to mention i would NOT rev the engine while the pushrods are pulled. I'm pretty sure they should stay in their homes at idle and even a little higher, since they sit pretty deep in the bores, but i have never tried this so proceed with caution.
EDIT
