hutch mod questions
Old May 9, 2013 | 01:56 PM
Tim Hodgson's Avatar
Tim Hodgson
Tugly: Cool. Is your reference to "ISSPRO EV2 dual Pyros" two gauges or a single gauge with two needles?
EDIT: Ok so looking at the ISSPRO website that would probably be two gauges:
1. http://www.isspro.com/product_detail...d=26&type_id=1 EDIT: Buy two of these, one for each manifold.
2. http://www.isspro.com/product_detail...d=26&type_id=1 EDIT: Do not buy for a dual pyro setup. (See Tugly's post below.)
The first is model no. 17021
The second is model no. 17092 and has a "#2" at the bottom of the face indicating that it is the second pyrometer. EDIT: DO NOT BUY for a dual EGT setup (see Tugly's post below).
And Fuel Pressure is:
http://www.isspro.com/product_detail...d=26&type_id=3
Thanks!
Last edited by Tim Hodgson; May 9, 2013 at 03:19 PM. Reason: To correct my error. See Tugly's post below. Thanks, Tugly!!!
Old May 9, 2013 | 03:12 PM
Tugly's Avatar
Tugly
  1. Forgot to mention... very cool filter up there. I want one.
  2. Don't get the #2. That's for a downstream sensor (look at the temp color range). I plan on getting another one like the one I have.
Old May 9, 2013 | 04:03 PM
Gary E's Avatar
Gary E
Why are electric oil pressure guages $20 and fuel pressure guages are $200 I don't see the diffrence other than the lettering on the guage?
Old May 9, 2013 | 05:29 PM
Gary E's Avatar
Gary E
well I ran around town picking up bits to put an underhood guage in today while tugly made a very valid argument for an interior fuel guage. anyway I am pushing 70 psi underhood at idle. I'll keep an eye on it and when it drops to 60 psi I'll swap filters, I know I have to be picking up a lot of junk in the bottom of that tank.
Old May 9, 2013 | 07:08 PM
Tim Hodgson
I think AZPete posted recently in another thread that he was happy with his Sun Pro gauges, and I believe they are significantly cheaper:
https://www.ford-trucks.com/forums/1...ar-gauges.html
I didn't see a fuel pressure gauge, in his post, but you may want to pm him.
Old May 9, 2013 | 07:18 PM
Chipworkz's Avatar
Chipworkz
The $210 price for the single fuel pressure gauge to match my other gauges is what made me go with the AeroForce scan gauge. Total after shipping was $325. It does the fuel pressure along with showing every other sensor on the truck. Now I will have my AE to record logs and this gauge to monitor everything when I am just out driving.
Old May 9, 2013 | 07:20 PM
Snowseeker's Avatar
Snowseeker
I need to check my fuel pressure after doing some mods. Just for checking I've heard before an air pressure gauge can be used. I assume this is true since the mechanics are the same but I have to ask, any reason not to?
Old May 9, 2013 | 08:24 PM
Tim Hodgson
I am way out of my league here, but I use a dial water pressure gauge (Home Depot or Harbor Freight?) for checking the well pump's water pressure at my place. Possibly this could also be used temporarily?
Old May 9, 2013 | 08:43 PM
Snowseeker's Avatar
Snowseeker
I am nearly positive it is alright since pretty much ALL mechanical pressure gauges just simply use a coiled copper tube hooked to the needle to show pressure. The copper tube just straitens out as the pressure inside of it raises.
Old May 9, 2013 | 10:04 PM
Gary E's Avatar
Gary E
Yeah I see no reason an electric oil pressure guage couldn't be used, I would not use mechanical as that would put fuel in the cab. For a nice set of guages I would just pony up for the fuel pressure guage, I have a three guage pillar mount maybe I should get a quad guage.
so the first filter didn't last long, about 6 miles and 1/4 mile down a bumpy road and fuel pressure went from 70 to 55 at idle. I cut it open it was pretty nasty but not terrible. crud dumped out of it when I turned it upside down. I don't know why its so bad if someone dumped dirt in it or if it just normally settles to the bottom and does not cause a problem. I guess then I went and stirred up 200k miles worth of dirt in the bottom
Old May 9, 2013 | 10:06 PM
Gary E's Avatar
Gary E
That scan guage is actually a great deal for all it does I am interested to see your pressure drop under load since we are running similar filters. My truck is stock with a chip yours is hotroded a little more but closer to my truck than Tugly
Old May 9, 2013 | 10:13 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
6 miles! Holy cow...mine has gone from 63 to 58 at idle over last three weeks. Looking for a 30 micron that will fit this filter head in Strictly Diesel's kit.
Old May 9, 2013 | 10:24 PM
  #28
carltonwebb's Avatar
carltonwebb
Hey Tug---Back to the filter restriction spin on discussion from earlier in this thread.
Based off what I think u said, could you not plumb a gauge that reads vacuum as well as psi to see what restriction the particular filter set up in question (whatever brand) is causing? We used to do that a lot with Case track hoes because of a ball that would get loose in the tank and cause issues. I think a gauge that read 30in HG - to 30 psi is just a few dollars at the hyd store.
Old May 9, 2013 | 10:29 PM
  #29
honeydew's Avatar
honeydew
Please post what you find. I haven't had any pressure fluctuations or changes with the Baldwin 1212 since installing the full fuel system but would like to run a readily available 30 micron at the next filter change.
Old May 9, 2013 | 10:35 PM
  #30
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Travis, my pressure drops like Rich's at WOT. All the way down to 39psi. Idle psi has been slowly creeping down. My tank was clean except for the pickup foot pieces everywhere. Maybe one or some of the little tiny pieces got together and clogged something.
