Help with a couple electrical gremlins, please.
Old May 7, 2013 | 08:21 PM
45FMJoe's Avatar
45FMJoe
1978 F-250 400/C6.
First is the fuel tank sending unit; the fuel gauge does not work. I pulled the sending unit and when it was completely inverted the gauge read full as it should. When it's installed, the gauge won't move. I tested the electrical plug and the light pulses brightly. I put dielectric grease in the plug and the needle moves just a hair from full to the left with the ignition off to the E, and its movement is very sluggish. Could this be the sending unit gone bad?
Second is in the lights. When the headlights are on, the right taillight will not work and the left brake light stays on. When the headlights are switched off, both taillights and rear marker lights turn on! I'm guessing that's a ground issue with the lights - probably a corroded socket somewhere in the system? Thanks!
Old May 7, 2013 | 08:47 PM
fmc400's Avatar
fmc400
MSEE
When you pull the sending unit and actuate it by hand (at which time the gauge registers FULL), is the sending unit hooked up and grounded in the same way it would be when installed? Yet when you install the sending unit and rely on the fuel level to lift the float, the gauge does not register correctly? If YES, the float is punctured and sinking to the bottom of the tank. Shake the float around and listen for gas sloshing around inside.
This is a textbook example of ground shift. 95% of the time, the problem is due to a corroded ground inside the socket itself. The solution is to replace the socket.
Old May 7, 2013 | 08:58 PM
45FMJoe's Avatar
45FMJoe
Thank you, sir! The answer to your question is yes so I'll pull the float out and check it. Thankfully it looks like LMC sells the float for $6. I wonder if I can get a float anywhere locally?
I thought it was probably a socket, I'll pull them and check them. Thankfully O'Reilly stocks them at the store down the street from my house.
Old May 9, 2013 | 10:58 AM
45FMJoe's Avatar
45FMJoe
Well, I didn't bother pulling the sending unit out again, just ordered a new float and gasket from LMC. My old gasket is shot and isn't sealing since fuel started leaking out. I'm waiting to pull it again when I get the parts.
I checked the front signal flashers and the tailight sockets, one is pristine. Three are seriously corroded. I'm just going to replace the three of them and go from there.
First I have to get this thing running properly, it barely runs. The previous owner's mechanic RTVd a 351C 4 bbl manifold to the block, it has no PCV valve and the "new fuel line" he told me about is nothing more than rubber vacuum hose. I'm thinking this is why there are a lot of air bubbles in the fuel filter. He bypassed the tank switch and ran a line from the side tank. I'm going to get new steel line from O'reilly and replumb the side tank. I'll redo the rear tank later. Oh, and the distributor seal needs to be replaced as it's leaking. He told me the entire engine has about 7,000 miles on a rebuild, so at least everything is fresh...
Old May 9, 2013 | 11:21 AM
Filthy Beast's Avatar
Filthy Beast
You know the Cleveland intake won't bolt to M block heads without spacers, yes?
M block deck heights are about an inch higher than the Cleveland's. Hence the gobs of RTV around the manifold. Won't work.
Any way to check that? Receipts?
Old May 9, 2013 | 11:26 AM
45FMJoe's Avatar
45FMJoe
Oh yeah, I'm aware of that...hence the RTV everywhere.
The seller was truthful. I'm a federal law enforcement officer, and after he sold me the truck he friended me on facebook - I'm positive he wasn't lying about anything.
Old May 9, 2013 | 11:58 AM
Filthy Beast
Ok, good...
On the float situation - Ford dealerships still carry the old brass type ones. Unless you're opting for a "plastic" one with an aftermarket sending unit.
Good luck chasing wires and the other "little" fixes.
Old May 9, 2013 | 12:49 PM
45FMJoe's Avatar
45FMJoe
Ah, thanks for the heads up. The tank has an aftermarket sending unit with the plastic float, so the LMC part will hopefully work.
Old May 10, 2013 | 11:12 AM
45FMJoe's Avatar
45FMJoe
Well, my PCV valve should be here today and I can sort that out and make sure my vacuum is good. After messing with the engine for a week straight after work (mind you I'm an amateur) I finally have it idling and running perfectly. I've been dealing with fuel delivery issues, timing issues, etc. I replaced the o-ring on the distributor because it was leaking and when I re-installed it, I brought the #1 piston to TDC and installed the distributor. All the sudden the truck runs like a brand new truck, it idles, revs, etc. Obviously the previous owner's mechanic had the distributor installed a tooth off on the cam and that was why the timing was so badly off. I retimed the engine, now to adjust the carb and do a final re-timing!
Le Juggernaught
Sep 5, 2014 03:37 AM
thegringo
17
Mar 22, 2014 10:49 PM
davewave649
Aug 22, 2012 03:27 AM
Elemak
21
Aug 17, 2012 01:13 PM
JoeVR5
Jul 18, 2010 01:07 AM
