Performance mods
Old May 6, 2013 | 09:20 PM
Dhsalzer's Avatar
Dhsalzer
Performance mods
I have an 86' f150 XL 5.0 EFI. I was wondering if there are any modifications I can do to increase better fuel economy. She's only getting about 8 mpg but I figure that is mainly due to the thrashed muffler and piping; a new one is on the way. I've switched out all the spark plugs, wires, distro and other various components associated. I'm mainly interested in replacing a cool air intake kit with the existing intake. Any help is much appreciated
Old May 7, 2013 | 08:55 AM
Archion's Avatar
Archion
Veteran: Marine Corps
8mpg is not due to the exhaust unless the cats are clogged. I regularly got 17hwy out of mine stock, 15 average. There are other issues at play here. Tire and wheel size and type, driving style. Pull the codes and see what you get. It already has a cool air intake and you will not improve the air tract, it is capable of supporting over 500hp as is. The heads on the 85-86 motors just plain sucked, very restrictive. Biggest improvements would be heads and a cam kit, but not a mustang cam. And remember, performance and mileage do not go all that well together in a truck
Old May 7, 2013 | 10:59 AM
Dhsalzer's Avatar
Dhsalzer
Sounds like a good start. I'm ordering a code reader today. The truck also emits a strong gas smell when running. I've checked all fuel lines and replaced the filter. I can't identify any fuel leaks and the smell is definitely coming from one of the many holes in the exhaust. I may have to adjust my gears as I don't really use first gear at all. I can start in second gear without even applying the gas peddle if I baby the clutch out. Not sure how to adjust gears so any tips will help
Old May 7, 2013 | 12:42 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
8mpg is in the Chevy 454 range. I got a solid 10 with mine when I first bought it. Now it hovers around 11.5-11.7mpg
Old May 7, 2013 | 12:46 PM
TheKirbyMan's Avatar
TheKirbyMan
Did you replace the O2 sensor?
Old May 7, 2013 | 12:51 PM
Dhsalzer's Avatar
Dhsalzer
I have not. I will add that to the top of my list. Thanks
Old May 7, 2013 | 12:52 PM
TheKirbyMan
I think the O2 sensor doesn't kick in until the engine's to operating temp, so it wouldn't affect idle I don't think. But when you're on the road it would.
Old May 7, 2013 | 04:49 PM
CountryBumkin's Avatar
CountryBumkin
Wow - 8mpg. I wish!
Old May 7, 2013 | 05:44 PM
Franklin2's Avatar
Franklin2
You have a serious fault somewhere. I would try to fix that first. Once you get your code reader going, it should tell something about what's going on with it.
Old May 8, 2013 | 07:10 AM
Dhsalzer's Avatar
Dhsalzer
Thanks for all the help. My fuel pressure regulator was the problem. It was pumping gas into a vacuum hose straight into the manifold.
Old May 8, 2013 | 03:43 PM
85lebaront2
That would do it. You might want to change the spark plugs now.
Old May 8, 2013 | 06:22 PM
Dhsalzer's Avatar
Dhsalzer
Done and done. No more rough idling, no more gas smell from exhaust and no more hesitation when accelerating. Thanks everyone for your help and input.
johnday
Computer Chips & Tuners
Feb 18, 2013 02:13 PM
Shwan_89HD
Mar 3, 2012 10:29 AM
novadragman2005
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 24, 2005 10:03 AM
SangRun Hunter
Jun 4, 2004 03:36 PM
black
Mar 5, 2001 04:52 PM
