1bbl carb
Old May 6, 2013 | 08:22 PM
82fordowner's Avatar
82fordowner
1bbl carb
Looking for a single barrel carb for 82 300 6 cyl four speed OD.
Old May 7, 2013 | 08:07 AM
hotstuff's Avatar
hotstuff
Are you looking for a Carter model YF ? I have some that might work for you . numbers are 7650 , 7655 , 7059 , 4598
Old May 7, 2013 | 08:25 AM
parkerparkerm's Avatar
parkerparkerm
How do you identify the 1bbl's? I have a carter on my f250(300-6) and I can't find matching numbers to identify it, and it needs a rebuild.
Old May 7, 2013 | 08:38 AM
hotstuff's Avatar
hotstuff
On the main body near the base their will be a stamped number , look close you will see it. should have had a tag ,but they are the first thing thats gets lost.The carb number has 4 numbers and s following
Old May 7, 2013 | 10:11 AM
parkerparkerm
Oh then it says 7565S. Is this still stock
Old May 7, 2013 | 10:19 AM
82fordowner
1llb carb
My carb is a motocraft E2TE-BVA. I'm not sure a carter will work. I talked to a guy that says he switched different carbs on his truck as long as the air line hookups were the same, but I don't have a way to tell if a carter would work. I talked to the ford dealer here and they said it was a original carb. My throttle is all worn out and real sloppy. I'll do some checking to try and find out if a carter will work thanks
Old May 7, 2013 | 10:57 AM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
The Carter 1 bbl is what came on the 300's, Model YFA
Old May 7, 2013 | 11:04 AM
hotstuff's Avatar
hotstuff
parker My book has a 7565 listed as a 1983 -300 eng model YFA
Old May 7, 2013 | 11:09 AM
hotstuff's Avatar
hotstuff
82fordowner I have a E2TE-CCC , if you are looking to rebuild yours . I think they are difference models
Old May 7, 2013 | 11:21 AM
82fordowner
I think I'll get a kit and try and rebuild mine, my throttle is real sloppy though and not sure how to tighten it up
Old May 7, 2013 | 12:49 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Check the end of the shaft where the lever attaches. Carter carbs and some of the Holleys were bad about the shaft staking getting loose with age.
When I get back to Newport News, I have a collection of Ford YFA carbs including a feedback one. I will see what I have.
Old May 7, 2013 | 01:13 PM
hotstuff's Avatar
hotstuff
You might have to put throttle shaft bushing in , if the base plate holes are wore
Old May 8, 2013 | 08:30 AM
parkerparkerm
So should I order a rebuild kit for an 83 carb? Are the rebuild kits any different?
Old May 8, 2013 | 11:42 AM
hotstuff's Avatar
hotstuff
the kit should be ordered by the carb number
Old May 8, 2013 | 03:13 PM
parkerparkerm
I meant to say should I go to the store and say I have an 83f250 with a 300-6 and order the kit with that number?
