Gas tank neck
Old May 6, 2013 | 09:05 PM
John R. Thomas's Avatar
John R. Thomas
Gas tank neck
I have a 75 F-150 long box with a single gas tank in the back.
It's a bear filling the tank. Gas ruined the paint below the gas cap.
The nozzle on the gas pump hose will not stay in the neck.
It's necessary to hold the nozzle and reduce the flow.
I have considered raising the box an inch or two to improve the flow.
Any suggestions?
Old May 6, 2013 | 10:04 PM
montana_highboy's Avatar
montana_highboy
That's a common malady on these trucks, i'm not sure there is a known "cure" but there are some fixes others have used to better the situation.
Old May 7, 2013 | 07:04 AM
Wbruiser2's Avatar
Wbruiser2
I had similiar issues, especially with the gas running down the side after a fill up. Upon closer inspection I could see that the filler neck opening was mangled a little not allowing the gas cap to properly seal. I replaced it along with the hoses and I don't have those issues anymore. I'm not saying I can fill it up as easily as my '09 F150 but it's 20 times better than it was.
Old May 7, 2013 | 12:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ck the condition of the large filler neck tube, is it collapsed? If so time to replace it.
As far as getting the nozzle to stay in by itself while refilling, you probably have the older large style leaded fuel filler neck, so forget it. Especially is the nozzle does not have the spring around it.
To at least be able to make it flow a little faster do the ol rotate upside down trick (the gas handle/nozzle) and you should be a little better. But yea you will have to still hold onto it.
Old May 7, 2013 | 03:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Vent hose taped to filler hose originally. If vent hose collapses, it makes these in-famous slow fill tanks...no fill tanks.
All 1973/79 Stylesides have slow fill tanks. Customers complained from the get-go, but there was nothing dealers do about it, as it has to do with the curvature of the fill tubes.
Old May 7, 2013 | 03:56 PM
Blang525's Avatar
Blang525
I have the same problem with my truck. I just keep a rag in the glovebox to wipe away the spilled gas. It is a major pain!
Dave_Yuhas
Feb 12, 2016 04:32 AM
raybob
Aug 28, 2012 11:54 AM
Nathan Plemons
Nov 17, 2010 08:39 AM
bigfoot22
May 23, 2009 07:37 PM
blackandwhiteglasspar
May 30, 2002 05:36 PM
