Electrical problem
Old Sep 11, 2010 | 08:34 PM
F250-76's Avatar
F250-76
Electrical problem
So out of the blue today, I try to leave the lumber yard, hop in the truck turn the key...(wait for it).........Nothing! Sometimes you turn the key and no lights come on at all, sometimes they are very faint, sometimes they come on like nothings wrong. Either way it doesn't do anything except click, sometimes. Cleaned the battery cables, no voltage drop between battery and starter solenoid. No opens between fusible links that I have found. I have 12.5 volts going to the distrubution box. I'm not to sure where to go next. I am going to clean up all the grounds and see if that helps, But I am lost because it was out of nowhere that all this happened.
Next thread; FOR SALE 1992 f-150 4x4 203,000 miles CHEAP!!!
Thanks for any advice!
Old Sep 11, 2010 | 09:18 PM
Elderstarr's Avatar
Elderstarr
How old is your battery? Checked it for dead cells or fluid levels?
You'll probably see a difference once you clean your grounds up. One upgrade I can recommend to anyone is to put a larger ground cable. I run 0 gauge.
Old Sep 11, 2010 | 09:43 PM
F250-76's Avatar
F250-76
yeah I thought, a couple dead cells or something so I tossed a battery from another truck and it fired right up. I went and bought a new battery, put it in and nothing. The ground cable for the battery is also pretty new.
oldworldwil
Nov 16, 2012 07:02 AM
allyfl
1983 - 2012 Ranger & B-Series
Aug 6, 2009 09:58 PM
burninrubber2416
29
Oct 11, 2008 08:34 AM
johare
Feb 6, 2006 07:53 AM
no_gamecocks
1966 - 1977 Early Broncos
Feb 2, 2003 05:54 PM
