equlizing air tubes?
Old May 6, 2013 | 05:12 PM
buzzy613's Avatar
buzzy613
On my SD 5.8 I was wondering if I made an x pipe, or an equalizer box for the twin intake tubes, if it would have anything effect on performance or would I just be wasting time making it?
Old May 6, 2013 | 05:32 PM
kermmydog's Avatar
kermmydog
From all my research on air intakes, Stock factory air intakes will allow more air than a stock engine requires. I believe all the CAI etc are a waste of money on a stock engine. If you want more air install a supercharger. That way the air is forced into the engine. Even stock paper filters let more than enough air in. The only time only aftermarket type filter I believe is good is the AirRaid dry filter. I say this if your doing a lot of dirt, dust or mud running. K&N lets too much fine dirt into your engine.
This is my two cents & years of running off-road.
Craig
Old May 6, 2013 | 06:13 PM
Conanski's Avatar
Conanski
You would be wasting your time, on trucks with the small block motors there are no bottlenecks upstream of the camshaft.
Old May 6, 2013 | 06:18 PM
buzzy613's Avatar
buzzy613
so by swapping the cam it would allow for more performance, what would be a good idle to 5000 cam for my 96 5.8?
Old May 6, 2013 | 06:34 PM
kermmydog's Avatar
kermmydog
First you need to determine what you want overall. Then you need to work from the ground up building. Just changing parts as a rule ends up a mess. So sit down & figure out what your end will be. If you want faster starts change gears. If you want fast top end change gears. Are you going to drag race?
Craig
Old May 6, 2013 | 07:48 PM
Conanski's Avatar
Conanski
The Comp XE264HR-14 but.. the motor will then run into the next bottleneck.. the stock heads and intake well below 5000rpm.
Old May 6, 2013 | 07:50 PM
buzzy613's Avatar
buzzy613
no sir she's a mean pullin' machine, I have 4.10s in her right now I want to do a lower end budget kind of build. with a little lift about 2in suspension, im going to run 285/75r16 with long tubes a low end cam and possible swap out the heads for gt40's
Old May 6, 2013 | 07:52 PM
buzzy613's Avatar
buzzy613
the reason for the rpm rang is I really didn't know what to put up tom I would be fine with a idle to 3000 or 1500 to 3000 cam since that's where itll be making the most power I believe
jazz1
51
Feb 24, 2014 09:38 AM
jez
Jun 27, 2012 05:46 AM
frt2599
Aug 5, 2010 05:44 PM
79 Camper Special
Jun 21, 2009 10:23 AM
eric777
Dec 20, 2006 09:27 AM
