At the moment I only have a Ford Car disc no truck. Car disc shows it going in the oil filter adaptor housing. If you have gauges it will be a big bell shape. If you have idiot lights it will be a small regular shaped one.
It has been decades since I did any auxillary gauges. As I recall most aftermaket gauges are Voltmeter. In a round about way they indicate "about" the same thing (Status of electrical system) I am assuming the Voltmeter is easier to hook up. Would be the same as hooking up a hand held Multi-meter.
That cleared both my questions up, thanks. Don't know how I missed that sender behind the filter...
A Voltage gauge is waaay more useful than an ammeter. Better yet if you have dual batteries cuz the reserve battery is always there in a pinch if ya need to self-jump.
Oil pressure sender? T'ed off the dummy light sender so it maintains the idiot light's functionality.
