Need help installing clutch assist spring
Old May 4, 2013 | 09:06 PM
emgee's Avatar
emgee
Thanks to Gary and Chris's help last November I managed to get a clutch assist spring (NOS Green Sales) for my 1980 F100. Now that spring has sprung it seems fitting to install this spring. I need advice on how to install it. How can I compress the spring in a way that it can be uncompressed when it's in place? Is there any special way to install it? I have good access and visibility as I did remove the dash pad and the instrument panel.
Old May 4, 2013 | 09:50 PM
ctubutis's Avatar
ctubutis
Is this the thing that fits in the pedal assembly?
Old May 5, 2013 | 10:27 AM
emgee's Avatar
emgee
Yes it is. Pedal Assist Photo by shortbox1 | Photobucket
Old May 5, 2013 | 10:35 AM
ctubutis's Avatar
ctubutis
OK.
I'd be inclined to try ChannelLocks or some such. There is probably some sort of special tool made for the job, maybe the Rotunda C5AB/32000-010 Spring Compressor/Artichoke-Pit Remover, but you'll prolly never be able to find one (or use it ever again)....
Old May 5, 2013 | 12:03 PM
6978sghfbjklgdfsjhkl's Avatar
interesting problem
In doing some research I've found a link to someone who used a unique method..basically wiring it compressed then cutting the wire once installed...
I'm sure it will be a job,
1983 Ford Bronco Hydraulic Clutch picture | SuperMotors.net
Old May 5, 2013 | 12:55 PM
emgee's Avatar
emgee
Thanks for that suggestion JohnSmith3524...sounds good! Compressing it first in a vice should work as long as the roller ends can be secured so it doesn't jump out and then wire it a few times.
Old May 6, 2013 | 08:21 PM
emgee's Avatar
emgee
Compressing the spring and wiring (2 wires to hold and 2 for backup) did the trick. It went in easily.
[IMG][/IMG]
woodhd
27
Nov 25, 2024 02:53 PM
unclejtl
Jun 12, 2022 06:21 PM
Harfend
Feb 10, 2008 01:04 PM
Brad Brown
Jan 23, 2004 09:36 AM
