My sunroof is occasionally leaking near the rear passenger door. Today I took the glass off and cleaned the seal and blew out the two front drains. They work great now. I tried to get to the rear drains with some compressed air - they both drain very, very slowly. I saw holes down at the end of the track and was able to rig a long rubber hose to get the the opening, but I am not sure it was the drain opening - despite some good puffs of air, the drains still do not work well.
Can these rear drain holes be accessed without dropping the head liner?
I did find the outflow of these rear drain holes, but it is up in the c-pillar and I can barely see it through a small hole in the frame - I tried hitting it with some air but it was not effective.
