Front end Vibration
Old Jul 25, 2002 | 01:41 PM
frey69's Avatar
frey69
Post Front end Vibration
Here is my Question. I have a 1988 F-150 4x4 with a ruumble or vibration in the front end while I am driving. It started to show up 2 to 3 weeks ago and is getting worse and I am at a lose. When I am driving until I hit around 30 it is fine. When I step on the gas it seems to go away. When I hit around 60 it becomes very noticable but when I let off the gas to coast it goeas away, and then when I feather the gas to keep it around 60 it is VERY noticable.
Does Anyone have any ideas?
Thanks
Old Jul 25, 2002 | 01:43 PM
winfordr's Avatar
winfordr
Front end Vibration
Sounds like a universal joint. That is exactly the symptoms they exhibit when the get loose.
Winford
Old Jul 25, 2002 | 07:04 PM
topo4u2's Avatar
topo4u2
Front end Vibration
I agree, it sounds like a u-joint. Try putting the transmission in Neutral when it is at its worst and if it goes away I can almost guarantee a bad joint.,
Old Jul 25, 2002 | 07:13 PM
GammaDriver's Avatar
GammaDriver
Front end Vibration
I'll third the motion, and ask you to check your rear U-joint - that's the one that went on mine (right after carrying a heavy load) and it had very nearly the same symptoms.
Old Jul 26, 2002 | 12:40 PM
frey69's Avatar
frey69
Front end Vibration
Thanks For the advice. Since I am a novice in the field of 4x4 trucks,
Is the front drive shaft turning while the truck is in 2H? If so that will explain the vibration. If not,what else might be the problem, Maybe the Motor mount? Also How can I Check the u-joint without throwing it into Neutral whlie I am doing 60+?
Old Jul 26, 2002 | 12:52 PM
michaelskerrett's Avatar
michaelskerrett
You can always get the truck up off the ground on jack stands, pull the drive shafts and inspect them (while you are there you might as well go ahead and replace them).
It won't hurt anything to put the truck in neutral while driving. Of course reasonable care should be taken. Do this on a clear stretch of road and take your foot off the gas when you shift so you don't over-rev the engine. What you are doing is taking the drive torque off of the shaft and it should return to the opposite side of the wear area if it is going bad.
Old Jul 26, 2002 | 03:21 PM
winfordr's Avatar
winfordr
Front end Vibration
jimlj
May 26, 2017 01:42 PM
RainHellFromAbove
Sep 12, 2012 09:00 AM
BroncoBoss351
1978 - 1996 Big Bronco
Nov 28, 2005 01:32 AM
lt6124x4
Jul 26, 2005 07:39 PM
clayduster71
Jun 28, 2004 05:29 PM
