S. California Chapter Join Chapter, Leader:
Oops rim size
Old Dec 16, 2016 | 06:23 PM
  #31
SpringerPop's Avatar
SpringerPop
That boy's BTDT before!
I'm impressed!
Pop
Old Dec 16, 2016 | 06:53 PM
  #32
wpnaes's Avatar
wpnaes
Plus he sweeps the remaining gravel off the trailer ledges so it won't hit our windshields. Class act.
Old Dec 16, 2016 | 10:30 PM
  #33
SpringerPop
If he's in Kalifornia, he'd BETTER clean it off! The CHP takes it very seriously about dropping stuff off a truck on the highway, and the fine is severe.
The mobile drill rigs that I've worked around are really careful about it before they leave a job.
Pop
Old Jan 16, 2017 | 03:47 PM
  #34
wpnaes's Avatar
wpnaes
A Beauuuutiful day, so why not spend a few more hours on the dent side.
... dang if those springs and axle wander all over when disconnected.
unfortunately I ding'd up my 'topknot' vent.
and the ole HF solar array is still charging.
Old Jan 16, 2017 | 05:36 PM
  #35
bpounds's Avatar
bpounds
An easy way to weather proof that damaged vent, would be to just add a vent cover. Like a Maxxair. https://www.amazon.com/Maxxair-00-93...air+vent+cover
It would allow you to leave the vent open all the time, and still be water tight. Helps prevent mold.
Downsides - it costs more than a replacement lid. And it definitely would no longer fit in your garage. Kinda looks like it doesn't fit now.
Old Jan 16, 2017 | 06:51 PM
  #36
wpnaes's Avatar
wpnaes
Thx Bill for the idea; the garage is definitely reserved for Missy's car. I only get to use the garage for auto work by reservation.
Old Jan 17, 2017 | 11:51 AM
  #37
SpringerPop
As Bill mentioned, be aware those vent covers are available separately as a piece-part.
However, there are a couple of different designs, so take the old one with you to the parts house.
Pop
Old Jan 17, 2017 | 05:40 PM
  #38
wpnaes's Avatar
wpnaes
Thanks Pop, it's looking rusty around the seal, so I might as well de-rust when I remove the door. It always pops open when driving due to ?venturi? effect.
Anyway, with rain on the way, I needed a MacGyver solution. Partially dried out 'tube of goo' worked.
In other news, received the new hitch and finished up adding the blocks. Ordered a new rubber brake line and steel tubing. I have a flaring tool around here somewhere...
Old Jan 17, 2017 | 06:53 PM
  #39
bpounds's Avatar
bpounds
All that goop needs is some rainbow sprinkles, and then it would look good enough to eat.
Old Jan 22, 2017 | 11:35 PM
  #40
Yama4fitty's Avatar
Yama4fitty
How's the goop holdin up? If it held today I don't think it'll ever leak again
Unless you try to back into the garage...
Old Jan 29, 2017 | 05:39 PM
  #41
wpnaes's Avatar
wpnaes
Held up good Chris, dry as a bone inside this week.
On another, similar topic, I'm working on the hard brake lines and bought a new flex hose. The hose heads up nicely to the frame cross member and there's a hole that I can attach it to. From there hard line up to the tongue.
My dumb question is how to attach that line to the cross member? What kind of fastener is that in the 2nd pic? How to get on/off? Do I buy another clip to slide into the flange on the same fitting buy on the far side of the hole?
added pics 3/4 for clarity.
Thanks!
Old Jan 29, 2017 | 05:45 PM
  #42
wpnaes's Avatar
wpnaes
Is it the gold colored flange in this pic?
Old Jan 29, 2017 | 08:25 PM
  #43
bpounds's Avatar
bpounds
Those gold clips are used like this.
The clip already on your line would be on the opposite side of the panel. Which means whatever the panel you are penetrating needs to be within a certain thickness range. The gold clips should have a little bit of spring to them, to handle different panel thickness.
Old Jan 29, 2017 | 08:43 PM
  #44
bpounds's Avatar
bpounds
If your panel is too thick to make up, you can remove that clip on the hose, and just let it seat on the face of the hex portion, or add whatever washer is necessary to get it all to work. Kind of looks like you're going to have that problem with the panel thickness. Not much groove is showing in your 4th pic.
Old Jan 29, 2017 | 08:50 PM
  #45
bpounds's Avatar
bpounds
It won't let me post the image, but there is a pic of the style of hose you have here: http://image.fourwheeler.com/f/65518...ry-brake-lines
The C-clip you have is on the near side, the U-clip you need is on the far side.
