Bronco II Ford Bronco II
rough idle
Old May 3, 2013 | 06:44 PM
wardee's Avatar
wardee
rough idle
Hi, just picked up a 1990 B2 that wa sitting in this guys garage for about 4 years, drained tank, put in fresh gas, new plugs,cap, rotor, wires,air filter, changed oil, starts right up but is running real rough, where do I go next, maybe a vacuum leak? any help would surley be appreciated> Thanks
Old May 3, 2013 | 09:07 PM
PetesPonies's Avatar
PetesPonies
How long was it running? Easiest thing to do is take an inductive timing light and connect to each plug wire one by one to see if there is an ignition miss. That would rule out of the ignition is all is fine. A vacuum gauge on a manifold port would answer your vacuum leak question. Did you change the fuel filter???
Old May 5, 2013 | 07:42 AM
wardee's Avatar
wardee
will try this out tomorrow, while I am at it, I think I will clean the injectors as well. Thanks again will let you know how things turn out.
Old May 8, 2013 | 10:37 AM
wardee's Avatar
wardee
Removed injectors, looked bad so ordered new ones, took out fuel filter and this redish liquid poured out of the filter, so changed that. I am going to remove tank and drain that and see what it looks like inside. Will keep you posted
MauleOne
Sep 27, 2011 05:58 PM
surfcraft
Mar 3, 2011 08:58 AM
Royson12
Sep 14, 2008 08:23 AM
2danglong
Apr 15, 2008 12:37 AM
55forder
May 9, 2002 08:58 AM
