Rough Idle
Old Apr 14, 2008 | 01:41 PM
2danglong's Avatar
2danglong
Rough Idle
possibly some dirty fuel from external tank. is it possible to bypass OEM filter? i've installed new inline filter and still have rough idle. how hard is it to replace injectors/solenoids ??? ford will dignose truck wednesday but if i can change injectors etc. it will be cheaper, am on a tight budget.
any help??
Old Apr 14, 2008 | 02:13 PM
MR5x5's Avatar
MR5x5
I had a rough idle caused by a bad ICP. Free to check, just unplug your ICP and see if it smooths out. The truck will default to a "canned" fueling table and will run and drive pretty normally. The ICP is above the front end of the drives side valve cover, immediatly adjacent to the fule bowl. If it turns out to be the ICP then look for a new one on e-bay for about $50.
Old Apr 14, 2008 | 02:16 PM
MR5x5's Avatar
MR5x5
Under valve cover harnesses will be another thing to consider, particularly if your getting a service engine light.
Old Apr 14, 2008 | 02:38 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Just a couple of thoughts here.
First check you oil. Both crankcase and HPOP. Really.
Second have you tried to drain any water out of the seperator?
Have you changed the OEM filter.
If you believe that the filter is dirty enough to be clogged up, then it is doing it's job.
You might consider putting another (bigger) filter ahead of the OEM filter.
Usually (damn near always) a clogged filter shows itself more at higher RPM's or heavy fueling loads than at idle.
One last thought.............iffin it's 2danglong, you shoulda got the SWB....
On edit----read your sig......now perhaps I am just envious!!!!!
Old Apr 14, 2008 | 03:53 PM
DieselCamper01's Avatar
DieselCamper01
Now thats funny!
"On edit----read your sig......now perhaps I am just envious!!!!!"
Old Apr 14, 2008 | 08:54 PM
mongo75's Avatar
mongo75
Hopefully you won't have tochange your sticks, but I just did mine and found that they were half of them were really gunked up on the fuel side. That's with a HUGE NAPA 3384 before the main filter. I still have a goofy idle though .....
P.S.- don't let the stealership gouge you- they wanted to charge me $4500 to do injectors, VC gaskets, UVC harness, glow plugs...... I did my injectors for $1300.
Old Apr 15, 2008 | 12:37 AM
2danglong's Avatar
2danglong
mongo- are those stock injectors ??? what is the cost of a new one or set. are these a ford-only item or napa ??
fourseasonsmi
Dec 19, 2012 12:10 AM
04_FX4
2004 - 2008 F150
Jul 19, 2011 05:45 PM
BigfootIDI
31
Jan 12, 2011 11:02 PM
paultfh
2004 - 2008 F150
Dec 2, 2009 03:00 PM
e_no_g
Jan 23, 2006 10:03 PM
