Air Intake Question??
Old May 3, 2013 | 02:00 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Originally Posted by rla2005
I went down this bunny hole a few years ago when I was searching for a 4.9/7.5L intake tube. Ford does not make it anymore and no one I contacted who specializes in NOS parts had one either.
I think this is the Ford part number for the air tube: E7TE-9C675-BC
I have a couple aside from a complete setup for my truck. I might be tempted to part with them at some point.
Old May 3, 2013 | 02:09 PM
iRockFosgate's Avatar
iRockFosgate
I'm just curious, but has anyone actually dyno'd the same truck with and without the K&N Cold Air Intake, the 4.9L intake hose, and just the stock box/hose? I mean is one intake after the other, after the truck has had time to cool back down and everything so it is a fair test for each intake.
Old May 3, 2013 | 03:19 PM
Encho's Avatar
Encho
The Southernmost Mod
You have a 2 into 1, so your truck is MAF, which is superior btw. MAF equipped trucks shouldn't use K&N wet filters, as the oil accumulate over time on the sensor and the truck will not run right.
Old May 3, 2013 | 04:41 PM
SideWinder4.9l
This is caused by over oiling. Regular/normal servicing will not cause that issue.
Old May 4, 2013 | 03:26 AM
2003EXPY's Avatar
2003EXPY
Plus cleaning your MAF once a year or so ain't a bad idea anyway.
Does anyone have some pics of the 4.intake and the 4.9/460 set ups they can post? This way I know what to look for when I go boneyard crawling.
Old May 4, 2013 | 07:24 AM
rla2005's Avatar
rla2005
From this thread: https://www.ford-trucks.com/forums/8...ir-intake.html
'96 Bronco
1978 - 1996 Big Bronco
Mar 2, 2010 03:56 PM
cchimuk
Jul 22, 2009 05:52 AM
quisp-n-quake
Sep 28, 2007 05:40 AM
mm68
20
Jul 20, 2003 04:02 PM
