E4OD and Transfer case wire issues
Old May 2, 2013 | 05:25 PM
SC6686's Avatar
SC6686
I've got a 1993 F150 4x4 with an E40D, roughly 150k miles. It is experiencing some shifting issues. It revs high in first to shift to second, and I am pretty sure it misses either second or third. However, if you turn the OD off at the point where you want the transmission to shift to second it will shift to second gear. You can then turn the OD back once you get into fourth gear. OD light is blinking occasionally. The only codes I have are 172 (the guy I bought it from ran true duals and didn't put in an O2 sensor), a 332 (a vacuum line replacement should fix this one) and a 634. I check the MLPS positioning today and it's spot on. Fluid seems nice and red and doesn't smell burnt.
My transfer case has 3 broken wires on it. A blue and green that are taped together and what looks like a brown wire. Here is a picture. My hand is covering the motor.
20130327_162700.jpg Photo by adamsja86 | Photobucket
The guy said the 4x4 doesn't work and is a loose wire. However when I start the truck the light on the 4x4 push button is lit. Am I running in 4high?
SwampFox112
1983 - 2012 Ranger & B-Series
Jan 24, 2017 07:49 PM
distortedcloud
Mar 25, 2009 03:04 PM
scottq
1978 - 1996 Big Bronco
Feb 14, 2005 04:52 PM
kidoo
Feb 8, 2004 11:10 AM
silvana
Bronco II
Feb 19, 2003 05:42 PM
