Blackstone report
Old May 2, 2013 | 04:42 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Blackstone report
I sent in my first oil test. Here are the results. I was pleasently surprised that it came back pretty good for what I can tell. With the miles and the abuse she has seen from the PO I expected worse. The oil type is Rotella T6 5/40 synthetic. I don't really know what I'm looking for but the comments sound good. Anyone know anything more about what I am seeing on my report? Thanks.
Old May 2, 2013 | 08:27 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Nothing in the report jumps out at me in the mineral content. The only thing that causes me concern is why you had to add 2qts in only 4000 miles. Are you burning oil? Rotella T6 is good for many more miles than 4000. In fact I wouldnt have even sent in the report until 5 or 10,000. But seeing as it is your first thats okay to get a bench mark.
Old May 2, 2013 | 09:12 PM
Crewcab Turbo
That was my concern I do use a bit of oil. That's why I expected a not so good report. Runs great and not a single drop of oil anywhere from anything.
Old May 2, 2013 | 09:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
How about smoke? Any on startup or on hard acceleration? Could be burning up in the turbo.
Old May 2, 2013 | 09:26 PM
Crewcab Turbo
I was getting a bit of white smoke at cold (below 30) startup after I got my 200/30 injectors. After tweaking the tunes and a Swamps moded IDM it has all cleared up. My truck has always used oil since I got it 70k ago. It gets 16 mpg hand calk in town and country roads stop and go in small towns, 19 on long hwy trips. Mabe that's why I got it for 7k, more than two years ago, which is cheap by me. Only smoke on acceleration is if I get on it hard in my Drag tune, and that's BLACK smoke.
Old May 2, 2013 | 09:57 PM
Bonanza35's Avatar
Bonanza35
Its nice to still get that kind of mpg with those sticks. That gives you both worlds, you can play and then you can drive. Have you tryed the Rotella T 15-40 to see if you use less oil? When I went from dino to Rotella T I don't add any oil any more between changes.
Old May 2, 2013 | 10:08 PM
Crewcab Turbo
I just changed back to Dino, 15/40 Dello 400 LE. I run synthetic in winter and Dino in the summer. I used Rotella only, 15/40 Dino in summer 5/40 Synthetic winter, for the entire time I owned the truck. I'm trying something different this time to see if there is a change. I do drive like an old man most of the time so that helps with the mileage.
Old May 2, 2013 | 11:45 PM
ranagent's Avatar
ranagent
I take it the molybdenum isn't bad, just above average? I just looked at my last report and it showed 3.
Old May 3, 2013 | 12:17 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
My MolyB was really low, too (like 3-5). Anybody know where exactly that originates from? I'm drawing a blank trying to figure that one out. I'd wonder about the magnesium in your sample as well.
What is your opinion of that Swamps IDM? I think that is my next mod if I get some good first hand experiences from others here on FTE.
Old May 3, 2013 | 12:48 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The amount of moly in the oil is deemed by the manufacturer. It is used as a protectant for the engine components. If fills small holes and scores in the metal to provide for smooth mating surfaces.
http://www.bobistheoilguy.com/moly-basics/
Old May 3, 2013 | 08:26 AM
lght1's Avatar
lght1
Hi
I would recommend doing a TBN next time. That way you will know the extent of EP degradation and base your oci on that number.
Old May 3, 2013 | 08:39 AM
timmyboy76's Avatar
timmyboy76
so, a higher # in Molyb is a good thing then, in a report? What about his sodium? Or is that the salt intake from his, past winter
Old May 3, 2013 | 11:21 AM
lght1's Avatar
lght1
hi
moly is a anti wear additive. its a goo thing but there are other additives that are effective too.
sodium could be in the formulation of the oil but also, it can mean a minute coolant leak especially with potassium. i would keep an eye on lead and copper amounts in that case.
AuburnAlum
May 30, 2018 09:48 AM
Firefighter 1406
6.4L Power Stroke Diesel
19
Jan 13, 2018 06:03 PM
ngng
6.7L Power Stroke Diesel
Oct 17, 2016 09:23 PM
RoofDude
Jul 3, 2013 08:12 PM
skullone
Jan 22, 2013 08:07 PM
