Stuck on gauge install. Quick help please
Old May 3, 2013 | 06:46 AM
Tugly's Avatar
Tugly
Originally Posted by pin8246
Yea mine I guess is through both, followed Clays directions to the T. Ill wait to see what its all about because its not to bad. One of my gauges seems to be more glitchy movements than smooth like the boost and pyro, think its the fuel pressure. Now thats annoying.
Ah... it may be working fine. Air in the fuel line can make your FP gauge twitch. Some boost leaks do the same thing - it twitches.
Old May 3, 2013 | 06:54 AM
pin8246's Avatar
pin8246
I figured it was something like that. It doesnt move all that much anyways, just noticed it because I was looking at it the entire time to see what it was doing.
Old May 3, 2013 | 07:06 AM
jeffreyt's Avatar
jeffreyt
I agree, you don't want to program out what you want to see. If anything, I'd want the speed increased for the fuel pressure gauge. I think the reason it looks glitchy is because it takes readings too far apart. Increase the frequency of samples and it should be more of a quick sweep instead of a jump. The temp gauges seem to be smoother because of how the heat transfers to and from the sender.
Rich, any input there? I don't have the software, I just downloaded and read the instructions a while back and am going off of memory and assumptions.
Old May 3, 2013 | 07:08 AM
Tugly's Avatar
Tugly
The fuel pressure regulator is not a precision instrument, it's a spring with a plunger-ish thing. Small movements are normal. You can program the sensitivity down to compensate, but that would negate seeing a pressure plunge when the power pedal is profusely pounded.
jt371
16
Sep 10, 2018 02:31 PM
Firefighter 1406
27
Dec 24, 2016 09:13 PM
William Mark Brown
23
Nov 8, 2015 07:37 PM
cps
15
Feb 13, 2013 09:56 AM
shark1979
Feb 26, 2010 04:29 PM
