po117 code 2003 ranger
Old May 2, 2013 | 11:11 AM
Gary E's Avatar
Gary E
which one is the ect? one is the ect and one is a switch for something?
Just gone done switching that POS plastic thermostat housing thing, both sensors were replaced not sure which one is throwing the code.
I have cleared the code and it keeps coming back.
Old May 2, 2013 | 08:46 PM
Rockledge's Avatar
Rockledge
Which engine? I believe the '03 4-banger uses a Cylinder Head Temperature (CHT) sensor to measure engine temps. (in lieu of the ECT).
If not a bad sensor, then there could be a short to ground in the wiring.
Old May 2, 2013 | 10:41 PM
Gary E's Avatar
Gary E
Thanks for the reply rock, turns out I had a connector loose its all good now, now onto sorting out why the ac compressor won't turn on.
Old May 3, 2013 | 06:42 PM
Gary E's Avatar
Gary E
sigh.... code is back 4.0 who the heck designs an engine that you have to remove the intake manifold to get to the ect, and then makes a leaky plastic container to house the thermostat. GRRR
Which one is the ect and I think the other one is a switch, what is the switch for? no electric fan.
Old May 8, 2013 | 02:18 PM
Gary E's Avatar
Gary E
still throwing the code I swapped the sensor out on the passenger side, as thats the only one I can get too without taking everything apart. It appears this code keeps the air conditioning from turning on, coolant guage works.
Old May 8, 2013 | 02:38 PM
Gary E's Avatar
Gary E
Old May 8, 2013 | 05:48 PM
Rockledge's Avatar
Rockledge
The one-wire temp. sensor is usually the "sending switch" used by the instrument panel temp. gauge. The two-wire sensor is usually the Engine Coolant Temperature (ECT) sensor that is used by the PCM for a variety of functions. (I have to assume it's the same way on your '03).
It's possible that a faulty ECT signal is causing the PCM to keep the A/C compressor from engaging.
The Ford Manual says code P0117 can be caused by the following:
- Grounded ECT circuit in harness
- Damaged ECT sensor
- Improper harness connection
- Damaged PCM
So you need to find the two-wire ECT sensor and replace it. If that doesn't do the trick, then you need to look closer at the ECT harness connector and wiring.
Old May 8, 2013 | 09:28 PM
Gary E's Avatar
Gary E
both have 2 wires I guess it has to be the really hard to get too one right
Old May 9, 2013 | 09:48 AM
Rockledge's Avatar
Rockledge
I can tell you that, for an '02 Ranger 4.0L, the ECT (PCM sensor) wire colors are: light green/red stripe & gray/red stripe.
The '02 sending switch wires are red/white stripe & black/white stripe.
There's a pretty good chance the same color wires are used on the '03.
Old May 9, 2013 | 10:06 AM
Gary E's Avatar
Gary E
Thanks rockledge, that would be the new motocraft one that you have to either remove the intake or unbolt the engine accessory bracket and remove the whole thermostat houseing to get too. no more 4.0s for me in the future.
crazymut
Mar 22, 2019 10:50 AM
menesesjesse
1978 - 1996 Big Bronco
Sep 29, 2011 06:30 PM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
rmarion
Sep 7, 2004 09:04 AM
ka1cu
Jan 20, 2002 08:10 PM
