i replace new metal sheet on floor in rear just need new body mounts and bolt cant do without mount or body will shake! and frames will hit metal floor make wrost not want do that!
Check with Prothane and/or Energy Suspension companies as they supply urethane bushings, have large selection of parts including some body mount bushings:
My crash book's only go back to 1992 so part numbers I can't provide. Contact FTE member NumberDummy via PM---he'll have those Ford OEM part numbers for you.
Prothane & Energy Suspension will have something suitable and if you want to go that route you'd need the OD of the existing bushings, the ID of the through hole and height or thickness too. I'm very confident one of them can help you.
Best of luck---its very frustrating trying to locate some of these parts!
