Ticking-only when excelerating?
Old May 1, 2013 | 07:44 PM
fallsburg04f-150's Avatar
fallsburg04f-150
Ok, I have done some reading here and from what I can tell I dont think that it is the cam phasers or cylinod. This only ticks when you give it gas. Sounds fine at idle, going down hill, anytime Im not on the gas. Any ideas?
Injectors mabey? Thanks!
2004 FX4 5.4 176000 miles, Ohio
Last edited by fallsburg04f-150; May 1, 2013 at 07:46 PM. Reason: forgot motor size
Old May 1, 2013 | 08:05 PM
Winter Brew's Avatar
Winter Brew
I chased this and it was the front hub actuators....they are engaged by a lack of vacuum. Try putting it in 4wd when going up a hill when you hear the noise. If it goes away, there is the issue.
Check the IWE hub thread for all the details if that seems to be the problem.
Old May 1, 2013 | 08:14 PM
fallsburg04f-150
I will try that in the morning and let you know! Thanks!
Old May 2, 2013 | 08:21 AM
dos0711's Avatar
dos0711
Exhaust leak possibly.
Old May 6, 2013 | 11:03 AM
fallsburg04f-150
Still does it in 4 wheel drive. With the hood open at an idle, I can not hear anything. Going down the road, when you give it gas, the ticking sounds like it is coming from the passeger side of the motor
Old May 6, 2013 | 11:06 AM
dos0711's Avatar
dos0711
FYI, my passenger side exhaust manifold leaks/ticks when cold or hot when under load.
Old May 6, 2013 | 11:08 AM
fallsburg04f-150
Thanks for the response Winter Brew and Dos0711!
Dos0711 shouldn't I be able to hear an exhaust leak at an idle as well?
Thanks
Old May 6, 2013 | 11:16 AM
dos0711's Avatar
dos0711
You can hear mine at idle when cold but not hot. Only under load when hot. I figure it to be a very slight warping that when it heats up slightly unwarps it...for lack of a better word.
Old May 6, 2013 | 11:35 AM
fallsburg04f-150
ok thanks dos0711! I understand and will pop hood again and listen a little closer.
ajschwab2004
2004 - 2008 F150
Jan 22, 2019 05:56 PM
sendmefishing
2009 - 2014 F150
Jul 21, 2017 10:33 AM
davbeisner
Feb 21, 2013 11:03 PM
Dennis Vadasz
2004 - 2008 F150
Feb 15, 2010 07:56 AM
wera racer
1983 - 2012 Ranger & B-Series
Jul 14, 2004 06:55 AM
