front hub
Old Jul 16, 2017 | 09:01 PM
sendmefishing's Avatar
sendmefishing
front hub
front hubs are making a clicking noise pull in 4x4 and it quits also when pulling camper or boat quits make noise when you let off the gas could this be a vacuum line issue or automatic hub issue?
Old Jul 21, 2017 | 10:30 AM
awq134's Avatar
awq134
does it make the noise all of the time or only when you accelerate/ have the engine under a load?
If it's all the time( except when in 4x4) it's probably the hub. If it only happens when under a load and quits as soon as you let off the throttle it's probably a leaking vacuum line or faulty vacuum reservoir check valve.
Old Jul 21, 2017 | 10:33 AM
Olytlr's Avatar
Olytlr
KingRanchMama
2004 - 2008 F150
Oct 20, 2017 06:39 AM
83sd
Jan 26, 2015 07:21 PM
bigsky22
2004 - 2008 F150
Sep 16, 2012 07:32 PM
Bakerboy
Mar 15, 2011 01:10 PM
Jpritchard
Sep 21, 2004 10:12 PM
