Reset Bed?
Old May 1, 2013 | 05:06 PM
chevyassasin's Avatar
chevyassasin
Reset Bed?
I was in a wreck about a year ago. It bent the frame a small amount but I have had it professionally bent back to specs but the bed is offset about a 1/2 to the right. My buddy and I discussed taking it off and looking for bent bolts or whatever else holds the bed into place. Is this worth the time or should I be looking more at the bed/frame?
Old May 2, 2013 | 07:40 PM
curkey's Avatar
curkey
When they did the frame repair they would have unbolted the box if not completely removed it. It's possible that when they bolted it back down they didn't line it up properly. I would try unbolting the box and seeing if you can align it better. You wouldn't need to remove it, just unbolt and push it where it needs to be. I don't know what year your truck is but I know the new ones are bolted from the top. They are also different lengths. If I recall correctly you'll need a T-55 socket for the new trucks. Hope that helps.
grinnergetter
Nov 11, 2011 06:07 PM
marine1200
1947 and Older Ford Trucks
Sep 23, 2011 08:04 AM
Stormj1
Feb 10, 2011 03:28 PM
pintoches
Feb 28, 2010 09:26 PM
Torque1st
Nov 11, 2002 05:01 PM
