Instrument cluster upgrade maybe?
Old Oct 9, 2013 | 10:29 PM
Visine's Avatar
Visine
I found a perfect instrument cluster out of a mid-70's Ranger XLT at the wrecker and got it for $20. It has the gauge for the oil pressure and alternator as opposed to the idiot lights I have in my 73 F100. Is this a simple plug in upgrade or will I have to rewire the plugs on back of the cluster?
Old Oct 9, 2013 | 10:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I have read on here you will have to do some wiring due the difference in the light versus needle gauge. I am sure some one will chime in with the answer.
fmc400 is that man on the elec stuff, he should see this and respond.
Old Oct 10, 2013 | 03:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year "mid-1970's" Ranger?
1973/76 F100/350: There are THREE different printed circuit boards used with oil/amp GAUGES.
Old Oct 10, 2013 | 06:30 AM
fmc400's Avatar
fmc400
MSEE
Idiot light vs. gauges are a completely different wiring setup. You'd have to modify the wiring all the way out to the voltage regulator under the hood.
Factory gauges are not worth the work involved, because they're meaningless in the first place. You're much better served installing a simple set of aftermarket gauges for oil/temp/volts. The factory ammeter literally is useless.
Old Oct 10, 2013 | 06:41 AM
77&79F250's Avatar
77&79F250
Well now I know that correct answer for next time, thanks.
Old Oct 10, 2013 | 07:25 AM
VocaTexas's Avatar
VocaTexas
Visine, if I recall the '73-'74 clusters were the same, '75 was a one year only with a stupid 'low fuel economy' light. "76 cluster was different from all those as well. Also, the clusters with oil and amp gauges take a different size plug from the ones with lights.
Old Oct 10, 2013 | 09:57 AM
Visine's Avatar
Visine
Post
Thanks guys for all the input. Looks like I'm going to have a $20 credit at Pick 'N Pull. I am amazed at the quick, accurate response I get from this forum with whatever obscure dilema I encounter. If any of you are drinkers and you make it to Tacoma, please look me up!
F-250 WARHORSE
Feb 6, 2018 10:11 PM
slour
Aug 21, 2017 11:11 AM
buzzy613
Jan 14, 2014 07:01 AM
Gembone
17
Aug 1, 2013 05:55 PM
Vin Man
Electrical Systems/Wiring
Nov 29, 2012 10:05 PM
