Fixed my problem!!
Old Apr 30, 2013 | 11:49 AM
04KingRanch's Avatar
04KingRanch
Fixed my problem!!
Had problems with my truck since December and finally broke down and took the truck to a very reputable shop to have the truck looked at. I thought that my problem was a fuel issue, but after the shop hooked the truck up to their computer it turned out to be a bad sensor. Turns out the Exhaust Back Pressure Sensor had a loose wire that was causing the electrical system to read under 5 volts and it was resetting the computer every time it wiggled loose. So, after 5 months of frustration, I spent $270 on service at the shop and it now runs as strong as ever.
I am also now running synthetic oil (Shell 5w-40) and the truck starts up better than ever...no more slow starts and poor idling.
Thanks to everyone who tried to help me with my issues,
Adam
Old Apr 30, 2013 | 05:20 PM
04badford's Avatar
04badford
Good to hear the good news Adam,and always a good feeling when you find the prob your selve saved your wallet a few more hundreds
Old Apr 30, 2013 | 08:12 PM
kidoo's Avatar
kidoo
Good news, shiit, how a small wire can make a difference with this engine
Old Apr 30, 2013 | 09:22 PM
BLADE35's Avatar
BLADE35
What Problem did it cause???????
Did it run Bad???
Did it SHut Off???
Sounds like it WOuld NOT STart???
OR ???????????????????
It helps us to know what Symtom went to what Problem if that makes sense
And will help those that Search Funtion on here
THANX
Old May 15, 2013 | 12:14 PM
04KingRanch
Did it run Bad???
Did it SHut Off???
THANX
It ran poorly to say the least, but what the really bad part was that it would short out the system. A wire connected to the exhaust back pressure sensor was really lose and the WIF light and coil light would come on at the same time when the truck had a load on it (when the turbo started spooling?). The connection was so bad that the truck would rarely run over 1500 rpm's...hard to get over 25 mph.
The truck started every time, except for a few rare occurrences.
From what I can tell, every time the truck got a load it would reset. As soon as the sensor was replaced the truck ran perfectly and we have not had any problems sense.
Adam
jemini
15
Aug 26, 2016 07:36 AM
bobj49f2
18
Mar 29, 2010 05:46 PM
R031Kona
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 9, 2008 11:24 AM
Colossus
General Automotive Discussion
Nov 5, 2007 03:38 PM
roller_steve
Nov 28, 2006 10:40 PM
