Sponsored by: Auxito
02 will not crank
Old Apr 30, 2013 | 11:24 AM
tlwood's Avatar
tlwood
02 will not crank
After short trip, 02 f-150 v-6 will not crank every time but engine turns over. When it does crank, it runs fine the entire trip. 189,000 miles on motor and is a 4x2 extended cab.
Old Apr 30, 2013 | 12:09 PM
Bluegrass 7's Avatar
Bluegrass 7
Cranking means it turns over with the key in start position.
Check the Crank sensor plug for being seated by pulling it off and reseating it back on.
If you have Theft system, try another key and observe the Theft lamp action.
Good luck.
c502cid
Jan 18, 2026 09:54 AM
Macrosill
May 17, 2015 04:09 PM
arj1231
Feb 16, 2014 08:07 PM
Chumbucket
Feb 3, 2006 05:57 PM
