New injectors
Old Apr 29, 2013 | 11:14 PM
1979BEAST's Avatar
1979BEAST
Question New injectors
So im almost done installing all my new parts and realized i forgot a step when i had the valve covers off i mightyvaced the back to cylinders out then after installing my new injectors i cranked the motor over by hand 10-12 times till back drivers side cylinder quit puking oil then i installed all my new glow plugs and valve covers up pipes turbo before realizing i never cranked it over with the starter!!
Should i pull it all back apart? What are do you guys recommend i do?
Old Apr 29, 2013 | 11:24 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
I would,an hour to pull it back apart or three hours to pull heads and replace bent valves.
Old Apr 30, 2013 | 12:03 AM
1979BEAST's Avatar
1979BEAST
How would it bend a valve? Prolly a dumb question but i figured hydrolocked motor or bent conecting rod?
Old Apr 30, 2013 | 12:24 AM
Bonanza35's Avatar
Bonanza35
If you can turn it over by hand now that it is back together it will be fine. Just make sure you spin it at least 2 , 180 degree turns.
Old Apr 30, 2013 | 12:39 AM
1979BEAST's Avatar
1979BEAST
Do i have to worry about bending anything when turning it by hand? And any tips to help prime the new injectors and hpop?
Old Apr 30, 2013 | 06:42 AM
Tugly's Avatar
Tugly
I have pulled VCs at least a dozen times... that is very minor work to make sure things are right in the world. I'm ****, but Stinky (the wonder truck) has suffered many an error and is still delivering the mail. If it were me, I'd pop the VCs, all 8 glow plugs, loosely fit the VCs back on, then crank with the battery to be sure. The back two are not the only ones that catch fuel/oil. It's not a waste of time if you gain confidence about turning the key.
Old Apr 30, 2013 | 08:08 AM
joeyd61's Avatar
joeyd61
x2....If you can turn it 2 full revolutions by hand, you are good..not enough pressure to hurt if you cant..
Old Apr 30, 2013 | 08:27 AM
jeffreyt's Avatar
jeffreyt
X3, if its hydro locked, you'll never spin it by hand. Give it a try by hand Atleast 2 full turns, and then get after at.
Old Apr 30, 2013 | 02:57 PM
1979BEAST's Avatar
1979BEAST
Okay she turned over over 3 full revolutions
now i need some ideas how to break the harmonic balancer loose im replacing the lpop mines leaking oil i have the puller on it and retaining bolt out im flexing the puller
Old Apr 30, 2013 | 03:10 PM
diesel-fitter-bum01
Pull the dust cover off the bottom of the trans. I used a wrench on one of the bolts and wedged it against the tranny case. Reverse for installation.
Old Apr 30, 2013 | 03:15 PM
1979BEAST's Avatar
1979BEAST
Its a manual im not spinning the motor it just seems like it wont pop off im putting alot of force on the jack bolt and its not budging
Old Apr 30, 2013 | 03:18 PM
diesel-fitter-bum01
oh,ok,I see what your talking about now. I had to soak mine in pb blater for a bit. Every once n a while tapping on the puller and spraying more on. Mine was tight too.
Old Apr 30, 2013 | 03:33 PM
1979BEAST's Avatar
1979BEAST
Well i sprayed it with pb before giving up on it last night so it will soak for 24h before i get back to it after work tonight
Any other suggestions and or tips if it still doesnt pop off?
Old Apr 30, 2013 | 04:22 PM
diesel-fitter-bum01
Keep trying
Old May 1, 2013 | 03:19 AM
1979BEAST's Avatar
1979BEAST
Alright i had a duh moment i never removed the retaining bolt washer after that pritty much just slid off
Now any body got any tips for priming the hpop oil system
Thanks for the help guys i really appreciate the help keep the tips coming
I just hope i dont have a bunch of gremlins to chase down over the last 21/2 weeks ive put in new uppipes 38r injectors glow plugs regulated return fuel sump and 1/2in fuel lines dual oem pumps t500 lpop
