Sorry this is a slow going built but keep watching as within the next few weekends ill be starting the swap. Heres a lil more done since the last post
VAlve covers freshly sandblasted
I sandblasted and vht'ed the manifolds along with new studs.
Ultrasoniced the injectors and ohmed them
Along with new water pump and timing cover installed due to above's misshap which is really funny becuase after I broke I realized I forgot one bolt on the old one -_-
And here is the harness all ready to go, labeled and just ready to be hooked up.
I didn't have to butcher the floor. The crossmember is a pain though. Beings mine is a short wheel base truck the frame starts to bend upward right where the mount is for the e4od and it has to be lowered 4 inches on mine.
Got a lot done on her and even got it started!! Now I just gotta finish up my shifter and the trans dipstick, fill up with some antifreeze and its ready for a test drive at least!!!
