Yep it's something they came up with at least 30 years ago and about the time they came up with the gas filler hose that traps any fumes............big waste of time and money if you ask me.
gas filler hose ? at the pump you mean ?
The evap is to catch fumes from expanding gas when it heats up while in your tank.
does anyone know why the bypass valve would fail and begin leaking coolant out the holes on the bottom? just replace it?, or is there a larger problem causing this ?
1. It's plastic and cheap.
2. It gets the hottest water the plastic can "safely" handle 100% of the time.
3. If it fails you won't know how to replace it (Ford hopes) and you will take it to the dealership and either trade it in or better yet spend a ton of money on something simple.
4. It's plastic and cheap (Yes this bears repeating).
