I've done EVERYTHING under the sun to get this beast to start. It was running fine and one morning I went out and it just turned over and would not start. No codes are being thrown. I have 35lbs of pressure on the fuel rail with key on. 12v to pump. Truck starts briefly with starting fluid in the intake.
Here's what I've done:
Replaced both fuel pumps(there are only 2)
Replaced fuel filter (there is only 1)
Replaced fuel selector valve
Replaced fuel selector on dash
Replaced all relays
Replaced battery and cables
Replaced fuel lines and vacuum lines
Replaced fuel pressure regulator
Replaced spark plugs
Replaced PCM
Probably a few more things I'm forgetting
I've had no less than 10 "mechanics" try to diagnose this thing. All of the above were done at their request. None of these things fixed or changed the problem. Next stop is the scrap yard if I can't get it running soon.
ANY help would be appreciated
Have you tested the ignition control module mounted on the distributor? They tend to go bad due to heat failure from being mounted on the distributor. That is why Ford switched to a remote mounted on on the 92+ trucks.
If that's the case it sounds like a fuel delivery issue. Since almost all of the fuel system is new, I would suspect something with the injectors not firing. I believe that still leaves the ICM as a possible fault.
When you replaced the PCM, was it new/rebuilt/loaned/pick-yer-part? I always taught my students to go with the adage, 'Just because it's new, doesn't mean it works'. PCM could still be bad.
Have you tested the injector ckts to see that you're getting power to the injectors when you crank the engine? A noid light would tell you that. Common 12V B+ to the injectors, each injector is fired by the PCM grounding the individual injector or in the case of Speed Density, firing the entire bank.
Thanks for all the replies. I'll check these things and report back.
The PCM was used. I don't think new ones are available. It still could be the problem. I can't even count the number of times I've bought new faulty parts.
Have you tried a known to be good coil? For some reason over the years I've had problems with 3 coils being bad intermittently,drove me nuts each time.
And they always tested good with an ohm meter
The pumps are the same, but the 4.9 uses a different regulator.
Since you used the shotgun approach to repairing this its difficult to say what the problem is.
If the regulator is new I'd check its part number online on the website for the store where you got it and see if it is the one for a 4.9.
If its not new I would check the fuel pressure with your guage before it reaches the fuel rail, at the filter is prob the easiest. If the pressure there is higher than the spec I would go buy the right regulator.
Sounds like a PIP problem to me. Go to Autozone and rent a noid light set. Pull an injector plug and plug the proper noid light into the harness and have someone turn it over. If it doesn't pulse a light, you have either a PIP problem or a computer problem. The PIP is the pick up in the distributor that tells the computer when to pulse the injectors. You can have all the fuel in the world but as long as your injectors aren't squirting that fuel out, you'll never get it to run. Also, I'm pretty sure you should be getting a code 11 (or maybe it's 111?) for "System Pass" as long as there's no other codes. If you're not getting any codes at all, that may be a sign of a bad computer.
Since shooting ether makes it start briefly I would be searching for a fuel related issue, the fuel pressure should be around 39-40 psi for the V8s, not sure about the I6, if it's 60 psi then this surely is the cause. The other possible cause I can think of is the TFI, which controls both the spark and the signal for the injectors.
I agree up to 60psi on the 4.9
Did he check for codes or just no CEL? The Computers on Fords are not a common failure.
Evan, I agree it has to be fuel.
My question is why didn't one of these 10 mechanic fix the problem? It would of been way cheaper to of taken this to a shop & had it fixed. Sure would of saved a lot of parts changing. Which is as a rule the most expensive way to fix a vehicle.
Craig
