Sponsored by: Real Truck
leveling wheels and tires
Old Apr 26, 2013 | 09:13 PM
moserfirefighter40's Avatar
moserfirefighter40
hey all I just picked up a 2003 F-250 supercab with a 6.0. i am wanting to get the rear up bout 1.5" and level the front to match. never having delt with leveling kits i was wondering whats the best way to achieve this. And also while im at it i am looking to put new black wheels on with some nice (obviously bigger) all terrains on if anyone has any suggestion for sizes and wheel off-sets and what not. Ive never owned an F-250 so im not sure what what all sizes and parts i exactly need. Any and all opinions and info would be appreciated
Old Apr 27, 2013 | 09:00 AM
02TB250's Avatar
02TB250
As it's a 250 there should be a 2" block between the axle and springs. You can lift the rear 2 " by adding a 4" block, either from readylift or icon or factory f350 block. The front is a bit different depending on what your truck had on it from the factory. With the plow package you may only need a mini leaf pack. If you don't you may need to get pro comp springs for the front. Doing anything to the front will require a new track bar. Zone offroad adjustable will run you about 100$. With a 2" lift you can fit 35s with minor trimming depending on your type of mud flap and rim.
Jo7.3
Oct 1, 2017 07:00 PM
Conrad Shugart
Jan 12, 2017 02:21 PM
Chris Popanz
Dec 8, 2014 07:30 AM
beemr
Jan 31, 2014 05:36 PM
Macmathews
Apr 7, 2010 04:31 PM
