Waterpump/timing cover job
Old 05-06-2013, 08:38 AM
TheGageinator's Avatar
TheGageinator
TheGageinator is offline
Job done!!
used gasket set part number TCS45450 $14.99
had to replace idler part number 231088 $17.99
lower radiator hose E71710 $14.99
Timing chain set $27.99
Belt 990k6
Thermostat OEM temp failsafe
i used a little bit of black RTV on the timing cover and GREY waterpump RTV on the waterpump and thermostat housing.
Old 05-06-2013, 10:07 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
I've never seen the timing cover out, great info and pictures!.
Old 05-06-2013, 05:44 PM
TheGageinator
Thanks! Hopefully this will help some people before they do this job.
I used the original timing cover even though it was damaged a little on the outside.I cleaned it very well and made sure that there where no damaged parts on the water or oil side that might leak. As soon as I have my intake pipe and radiator in, I am going to start it up! Hopefully I wont have any leaks!
Old 05-09-2013, 06:55 AM
TheGageinator
changed spark plugs, oil, both radiator hoses, and a couple of coolant hoses. Took it for a test drive for about 15 minutes. it drove great no leaks so far! ill drive it some more today and test for leaks.
Old 05-22-2013, 04:12 PM
mscham's Avatar
mscham
mscham is offline
Just wanted to say thanks for your pic's. You helped me figure out what bolts in the pile o bolts that came off my truck to use when for both the timing cover and water pump.
https://www.ford-trucks.com/forums/1...ther-fixs.html
hopefully, I'll get mine back together soon so I can see how many leaks I do or don't have anymore. ;-)
Old 07-07-2013, 08:29 AM
TheGageinator
no problem!! good luck man hope it goes well. be carefull with the cast aluminum , dont beat on it too hard haha
Old 07-26-2013, 08:35 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
I dont want to diss that fram filter you have on there, but there is plenty of documentation about how inferior they are. If you get a great deal at your shop on them, great, but i would at least use a purolator filter.
Nice thread! Thanks for all the pics!
Old 07-26-2013, 10:21 AM
BenS77's Avatar
BenS77
BenS77 is offline
I must have been really lucky with mine. I just pulled all of this off earlier this week.
I took my time cleaning the timing cover and what not. The bolts were a little rusty, but I didn't break any. I cleaned up the bolts on my bench grinder's wire brush before re-installing the cover. I probably should have used some anti-seize on the bolts, but I didn't have any.
Did your oil pan gasket have a metal frame inside it? Mine did, and I didn't cut it off under the timing cover like the gasket instructions said to. I cleaned it as best as I could with shop rags, put a little red RTV underneath the oil pan gasket and on the ends under the crank snout. I did use the new half circle gasket under the crank snout with more RTV.
I pulled the intake manifold off also, since mine was leaking coolant in the front and rear passages. The lower manifold bolts were finger tight in places, so that's probably why they were leaking. I'm probably going to have some difficulty getting the distributor lined up properly since I've spun the engine since pulling it out.
Old 07-31-2013, 02:41 AM
Krisverde's Avatar
Krisverde
Krisverde is offline
Random...but I bought the arp bolts from latemodelrestoration along with a timing cover. Noticed that the water pump is different for a fox body vs the waterpump on my 302 in my 89.
wirelessengineer
20
11-18-2016 08:13 PM
2.5itim
09-14-2016 08:33 PM
MUDBUCKET
1978 - 1996 Big Bronco
18
04-07-2014 08:11 PM
beagledog
34
07-13-2010 10:26 AM
scott9320
10-21-2002 08:44 PM
Quick Reply: Waterpump/timing cover job
