Rear end swap
Old Apr 25, 2013 | 09:27 PM
tw65f250cs's Avatar
tw65f250cs
Rear end swap
I was hoping someone tell me if a Dana 60 rear end with 3.90 gearing from a 1957 F100 would swap easily into my truck. I have a 1965 F250, 352, Dana 60 with 4.10-1.
Would the change in gears help much with my highway speeds or should I wait to find a 3.73 or 3.54.
I've done some extensive reading of past threads but was specifically curious about this rear end I found for sale. Thank you!
Tim
Old Apr 25, 2013 | 09:44 PM
dman2008's Avatar
dman2008
What kind of speeds would you like to go? I think that 3:25 or 3:00 at minimum, or adapt an OD of some sort into it. Pricey but well worth it.
D
Old Apr 25, 2013 | 09:51 PM
tw65f250cs's Avatar
tw65f250cs
60 or above would be nice... without screaming down the 101!
Old Apr 26, 2013 | 12:45 AM
SuperSabre's Avatar
SuperSabre
Assuming you want to stay with the Dana 60 rear end, you'd be better off finding a 3.54 set of gears. There's not enough difference between 4.10s and 3.89s to be worth spending money to make the change. Oddly enough, I ordered a brand new '71 Plymouth Road Runner 440 6 pack with a Dana 4.10 rear end (part of the Super Track Pak), back in the day, thinking I was gonna attach a Hone-O-Drive overdrive unit to it - and after I got the car I found out it wouldn't work. So I swapped the 4.10s for 3.54s and was very happy with it. Good luck!
Old Apr 26, 2013 | 05:44 AM
jowilker's Avatar
jowilker
Dman, He has the Dana 60 not the Ford Nine in.
John
Old Apr 26, 2013 | 08:23 AM
dman2008's Avatar
dman2008
John
Well I only speak english . Well swap the rear to a 9" only way, pick n pull close by?
D
Old Apr 26, 2013 | 08:47 AM
37 Ford guy's Avatar
37 Ford guy
Tim
Plug your specs into this calculator and see if it makes much difference. Calculators
Old Apr 26, 2013 | 10:18 AM
tw65f250cs's Avatar
tw65f250cs
Thanks for the input everyone. I think I'll pass on the 3.90 at this point... I would probably like to stick with the Dana 60, not change over to a 9 inch.
Is the 3.54 gearing only available on the 9 inch? And does anyone know which trucks to look for at the pick a part that would possibly have a 3.73 Dana 60?
Old Apr 26, 2013 | 01:41 PM
dman2008's Avatar
dman2008
No I believe summit sells a 3.54 set for the dana 60. I run 3.50 in my 9" and it revs about 3000rpm at 65mph.
D
Old Apr 26, 2013 | 02:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No F100 came with a Dana 60, F250's only. F100's have 5 lug wheels on a 5.50" bolt circle. F250's have 8 lug wheels on a 6.50" bolt circle.
3.54 ratio introduced in 1966 F250 Dana 60.
Other Dana 60 ratios 1953/79: 3.73; 4.10; 4.56; 4.88 / 1980: 3.00 & 3.23 introduced.
Lotsa luck finding 3.54 or 1980 and later 3.00 or 3.23. Everyone one wants one, few find them.
SuperBeaner
Jan 7, 2014 07:51 PM
F250Wheels
Jan 13, 2009 09:01 AM
knash0727
Jan 5, 2008 12:21 AM
MILLHOUSEB
Sep 8, 2006 02:03 PM
Snowking
Mar 31, 2006 06:41 PM
