need adivce...updated/resolved!
Old May 2, 2013 | 03:56 PM
bryanlindborg600's Avatar
bryanlindborg600
need advice....update
well the cps isn't the issue, put the one from my other truck in and no difference, i did notice my egts get hot quick, they jump to about 320ish in just a few seconds, not sure if that could help with any ideas or if it is to be expected when the truck is running with a "miss"/rough?
anywho just thought id post up my most recent blind stab at my problem.. the good news is i do have a perfect running truck i can swap parts with to know for sure before i buy a new one!
Old May 4, 2013 | 11:41 AM
bryanlindborg600
update
well after a couple emails with aeroforce i got a phone number and talked to somebody and it sounds like i have either a gauge or cable problem, so i am shipping it back to them to look at it. hopefully it all gets resolved soon and i can pull some codes on ol' CC and figure out what it's gonna take to get her up and running..hoping it is something "cheap" lol... yeah right huh....!!
anywho ill post back up when when i get the gauge and codes....hopefully...
Old May 8, 2013 | 04:02 PM
bryanlindborg600
Well i wait for my scangauge back i want to look into my uvch's because i am not patient!! i know i can ohm them instead of having to pull the vc's to inspect them, but does anybody have any info on what id be looking for as far as knowing if i have uvch's isuues.. would i just get a "dial tone" sort of speak or will it be obvious if i have bad/burnt or whatever else connection..?
hope what i am trying to say isn't too confusing..
Thanks in advance
Old May 8, 2013 | 05:43 PM
Ken_C's Avatar
Ken_C
ok i know it sounds crazy but if the cigarette lighter fuse is blown you could have issues with obdii port. so might want to check that.
Old May 8, 2013 | 06:51 PM
bryanlindborg600
been checked and replaced just to know for sure already..but thanks!!
Old May 9, 2013 | 05:58 AM
427 fordman's Avatar
427 fordman
If you ohm the injectors, they should be about 3.2 each. If you pull the vc's, you should be able to see any burnt connections.
Old May 22, 2013 | 06:37 PM
bryanlindborg600
got it fixed today i wanted to post up my findings, after pulling some codes and some discoveries discussed in my other thread, need advice take II, i swapped idm's from truck to truck and the CC is running as it should! wanted to post in both my threads that it has been resolved!
imjwm
Oct 3, 2014 04:27 PM
Beauderek
Sep 17, 2011 04:51 AM
iggipsd96
Oct 22, 2009 11:14 PM
SUPERDUTY OUTLAW
Dec 26, 2008 05:20 PM
ncm0008
29
Jul 16, 2008 11:17 PM
